Old 03-24-2015, 02:33 AM
phil2000 phil2000 is offline
Default Erratic behaviour with 'Write to all enabled' PT 10.3.10
Hi all,
Some plug-ins (DSM, bx digitalV2 - yes, both from PlugIn Alliance) are not always writing their settings if I use 'write to all enabled'. Anybody else seen this ? So I reverted back to 10.3.8. AGAIN (just like after the input monitoring disaster), and everything is working again as expected.
Oh well, I guess this is just the end of the line for PT 10....
Best- ph!L
Old 03-24-2015, 05:35 AM
Drew Mazurek's Avatar
Default Re: Erratic behaviour with 'Write to all enabled' PT 10.3.10
http://plugin-alliance.com/en/support.html
Go here. Halfway down the page there's an FAQ that mentions PT and automation. See of that's what you're experiencing.
www.drewmazurek.com
Old 03-27-2015, 11:17 AM
maxsoundvibe maxsoundvibe is offline
I will check on mine. I need a staple pro tools 10 since I NEED my TDM plugins.
Erratic behaviour of Mbox 2 Pro with PT11 nyjdams Pro Tools 11 0 12-22-2014 06:14 AM
Write to all enabled on d control garret Post - Surround - Video 1 03-29-2011 05:22 AM
'Write to All' in playback behaviour thermisonic Post - Surround - Video 3 03-24-2010 07:53 AM
Write to all enabled parameters webstereo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-06-2005 10:39 AM
Erratic crashing behaviour allthatglitters 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-11-2004 07:13 AM
