Go Back   Avid Pro Audio Community > General Discussion & Off Topic > Buy & Sell
Old 11-30-2013, 12:10 PM
SmartGear SmartGear is offline
Default WTB: XMON cable
In need of an XMON cable if anyone has a spare one. Thanks!
Old 11-30-2013, 02:56 PM
Brandonx1 Brandonx1 is offline
Default Re: WTB: XMON cable
Isn't an xmon cable just a midi cable?
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 11-30-2013, 08:09 PM
Craig F Craig F is offline
It's easy enough to roll your own or get a 15 pin straight through cable if the run is short enough
Thank you,
Craig
Old 11-30-2013, 09:20 PM
Buccanears's Avatar
Buccanears Buccanears is offline
If it's an ES console, there is some wiring that needs to be no connection.
Check the back of the latest ICON manual for diagram. The PDFs in the web archive are wrong. PINS 3,4,11,12 should NOT be connected.
The V8 PDF is correct, see
http://avid.force.com/pkb/articles/e...641?popup=true
If rolling your own, see http://akmedia.digidesign.com/suppor...db15_44797.pdf
Don't use a straight through cable unless you want to see shenanigans with
your com board and xmon. I've been there. It ain't fun.
Q "where are your buccanears?"
A "on your buccanhead!"
IMDB
Old 12-01-2013, 06:59 AM
Thank you for your replies!
Yes, it's a D-Command ES.
I was gonna do it on my own, but got confused about the wiring.
I have V8 printed in my hands and it says for 12,4 and 11,3 MIDI in and out.
And everything coming from AVID/Digi says the same.
So what am I missing here?
Old 12-01-2013, 01:04 PM
the MIDI cabling is for diagnostics and for the System 5 MC / software control or the XMON
if you want the breakout https://www.dropbox.com/s/5x4h5xcycb...ol%20Cable.pdf
Thank you,
Craig
Old 12-01-2013, 09:39 PM
Buccanears's Avatar
Hi Smart Gear,
My posts were referring to D-Control ES wiring. I had a wee look at the D-Command V8 diagram and lo and behold the 4 connections are back.
I definitely know that they need to be snipped for a D-Control ES. Now very confused with D-Command...
IMDB
Old 12-02-2013, 03:27 AM
Bill Denton Bill Denton is offline
Something I wondered about when I was reading this thread yesterday...
Is it possible the D-Control and the D-Command use different cables?
Just a thought...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 12-02-2013, 08:15 AM
No, same cable
I've installed both units
Thank you,
Craig
Old 12-02-2013, 01:39 PM
Buccanears's Avatar
I'll buzz out a new cable and see what I find. Stay tooned!
IMDB
XMON Eucon Software and wiring Control-Breakout Cable moacito System 5 3 05-02-2013 08:26 PM
XMON Cable shed man ICON & C|24 5 04-24-2013 01:05 PM
Cutting XMon Cable? SimonInAustralia ICON & C|24 1 03-27-2009 01:07 PM
Is cable for 24|Mix -> 882/20 standard SCSI-2 cable? Last Legend Pro Tools TDM Systems (Mac) 2 01-18-2003 12:36 AM
Digi 001 I/O Cable Question (need longer cable) M@tt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-15-2001 10:08 PM
