bit rate and bit depth
Could someone explain the difference between bit rate (8, 16, 24) and dither bit depth (16, 18, 20)?
Pro Tools 12.6.1 for Windows 10 ASUS Core i7 3770 Yamaha Steinberg UR 44 Golden Age Project Pre-73 JR Warm Audio WA12 MKII Preamp Glyph 1TB GPT50 external drive - Firewire LaCie 1TB external drive - USB JBL LSR305 monitors AT 2020 & 2021 Equation F.20 condenser mic |
Bit rate is basically your head room before you clip (the audio) the higher the bit rate the better or more headroom you have
Dither basically refers to after you're ready to mix the 2- track down to a CD quality depth Dither is basically used after you're done with everything in the song But your bit rate you want to use the highest available PT 10 is 32-bit PT nine and below is all 24-bit
Re: bit rate and bit depth
Perfect. Thanks for your answer.
I'm afraid you are both confusing things. Bit rate is the # of bits transferred over time (e.g. per second) in any transmission line. It's basically the same as sample rate (sample frequency), typically 44.1 kHz, 48 kHz, 96 kHz etc. Bit depth (or sample depth) is the resolution of the transferred data, e.g. 16 bits, 24 bits etc. Dither applies to changes in bit depth, not bit rate (sample rate).
Bit Depth & Sample Rate... | pguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-10-2017 01:16 PM |
32 bit depth, sample rate? | papitopinillo | Pro Tools 9 | 23 | 08-30-2011 05:14 PM |
bit depth, sample rate? | badda | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 02-21-2007 10:49 AM |
Plz Help! Sample rate and bit depth | Mekko | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-16-2005 08:09 AM |
sample rate and bit depth | dracos | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-02-2004 07:41 AM |
