Apogee Trak2 with TDM vs LE
In researching different aspects of the limitations of a Digi001 system, it sounds like the hardware is the main problem negatively affecting the sound quality of LE systems. I have read some postings by people comparing RTAS to TDM versions of plug-ins and the difference seems minimal. The main drawback appears to be the preamps, converters, and clock of the Digi001 hardware. By using an Apogee Trak2 as the core hardware for an LE system to replace the pres, converters and clock of the Digi001, I would think that there would be no difference in sound quality between an LE system running off of a Trak2 and a TDM/Trak2 system. (If anything the LE/Trak2 system should be a little better than a mix system due to the summing bus, right?)
This of course assumes that I only record at 44.1 or 48K, I don’t need more than 32 tracks, and I have enough processing power when combining the host processor with outboard reverb units. Would you agree that this is the case, or am I missing something? |
Re: Apogee Trak2 with TDM vs LE
I would think you have a good approach. And with the newer processors, you could definitely end up with more dsp power than the average Mix system... [img]images/icons/wink.gif[/img]
Can you please send yourself over fiber to go spam some other forum? Darryl Ramm |
how do you plan to connect the Trak2 to the 001?
The Trak2 has multiple connecting/routing options. It has spdif out for two tracks and word clock into the back of the digi001. With a AMBUS ADAT option card, you can connect with lightpipe, also accessing routing for 8 channels of digital signal within the Trak2.
I wish the Trak2 had a spdif in, not just a spdif out. That would help with routing an effects unit without converting to analog and back to digital. I haven't seen any effects units that have optical I/O for digital. Does anyone know of any? |
Mini Me vs. Apogee Trak2 | moblues | Pro Tools TDM Systems (Mac) | 0 | 01-31-2004 02:27 PM |
Apogee Trak2 on Sale? Where and how much.. | Trash Man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-11-2003 08:33 PM |
Apogee TRAK2!!!!!!!!!!!!!!! | CCash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 11-14-2001 11:22 AM |
Apogee Trak2 | Bryan | Pro Tools TDM Systems (Mac) | 2 | 04-24-2001 07:13 PM |
Apogee Trak2 | verfonce | General Discussion | 1 | 08-30-2000 05:27 PM |
