Old 09-28-2009, 08:37 AM
Fidelis Fidelis is offline
Default 2 MC Mix or 1 Mc Mix + Mc Control
Hello friends,
I just bought one MC Mix for my PT HD3 Accel. Very happy with it. The limitations on the HUI protocol didn't bother me, 'cause I using it for fader automation and just a few plugins changes. So I decided to add more faders to it.
I'm trying to decide between one more MC Mix (total of 16 faders) or one MC Control (12 faders + touch screen control). One down side I see on the MC Control is that HUI sees 8-bank faders and with just 4 faders on it I could only see 1-12 first channels and if I bank it to the right it would jump for the 17-28, missing channels 13-16. The upside would be the transport control plus the touch screen controls.
Question is: Is there much use of the touch screen for Protools? What can I do there that I can not with keyb shortcuts (i'm really fast on that)?
Thanks for the help!
PS. I can not test MC Control down here in Brazil cause Euphonix doesn't have an official distribuitor down here so I have to import myself!
http://www.ricardomosca.com
Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard
Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0
Old 09-28-2009, 09:42 AM
zeeman zeeman is offline
Default Re: 2 MC Mix or 1 Mc Mix + Mc Control
hey Fidelis
i have the same setup you are using.
i have the mc mix and 1 mc control in 2 different rooms.
the whole banking issue is a drag. but i have gotten used to it.
i do use the mc control quite a bit for plugins.mostly the ssl/emi plugs.
i really like the control i get. i never use the jog wheel. i do use the transport section all the time.
if you are not using the mc control to control plugins and you don't need the transport function of the mc control, then my thought would be to go with another mc mix. you wont have the odd banking by 12 issue.
also keep your eye out for updates from euphonix, they do updates quite frequently.
hope this helps
zeeman
Old 09-28-2009, 10:31 AM
JSR JSR is offline
I am right about to go with the 2 x MC Mix; have you guys inquired about if the devices would be supported past this next version of Pro Tools? I'm in NYC, so I'm going to run it by the Euphonix reps at the AES show next week. I'm assuming HUI, etc will continue to be supported, but wanted to be sure before dropping a few grand.
Thanks.
JSR
Old 09-28-2009, 10:38 AM
yea it's been on my mind, that's for sure.
right now it's working in PT 8.0.1
only a matter of time before the hui protocol is gone i would think
we'll see
zeeman
Old 09-28-2009, 11:22 AM
Hey Zeeman,
thanks for the fast answer. Let me get it right: You use you MC Control for plugins control. So you control your plugins from it using the the 8-rotary soft knobs or from the touch screen? If it is from the 8-rotary soft knobs, that would be no difference from the MC Mix right? If it is from the touch screen it news for me. I didn't know it works that way. And what else do you use the touch screen for?
Thanks again!
Old 09-28-2009, 01:07 PM
sleadley sleadley is offline
I have been Demoing the MC Control and Mix in my edit room and I am very impressed. Yes, Hui limitation, but guess what, at least you can put the channels into auto modes unlike the C8 and you get 12 Faders. The Touch screen is brilliant for shortcuts and the Mac Software is very simple to use once you get your head around it.
The Surround panner works and best of all the unit is very slick and has a great profile for editors and Premixing TV work.
I would have liked Digi to create a mid controller like the MC, with ICON protocol and expanded features like the MC but still no Go on this front. The other DIGI controllers are simply to large for most edit rooms, not to mention portability. We need a C8 Pro, With a touchscreen and the ability to hook into larger ICON systems if necessary.
my 2c
Simon L.
Plan for the worst, Hope for the Best.
www.trackdown.com.au
Old 09-28-2009, 01:11 PM
i don't think i use the touch screen at all.
i use the 8 rotary knobs.
at first before i got the mc control i tried to control the plugs from the 8 knobs on the mc mix but it became a little cryptic but i did get used to it.
i was still faster with the mouse.
on the mc control things seem to be laid out better and i use the knobs in a much faster way.
i was trying to get away from so much mouseing around.
as far as the touch screen i know you can select/solo/mute tracks and such but i really don't ever use it or the jog wheel.
like you i use the faders and knobs and that gives me( for the money) a nice little controller
hope this helps
zeeman
Old 09-28-2009, 01:51 PM
BradLyons BradLyons is offline
Well, this is really a decision only you can make----I recently considered selling off my Control24 and getting (4) MC Mix plus an MC Control unit---but decided to keep the Control24, buy a C24 later, and still get an MC Control for Final Cut and later add an MC Mix for Logic. ANYWAY....the advantage to another MC Mix is obviously more faders. The advantage to the MC Control is to get anywhere quickly and easily, you're only a touch-away. If you want to pull up your groups, BOOM....how about selecting your Playlist, BAM....etc. IMHO, I don't think that the MC Control can replace the Mix and vice versa. Either way, it's no C24----but it certainly does have its advantages as well. I've sold quite a few of these to Protools users after having reservations early on, but so far---the feedback has been good---depending upon their needs of course.
Thank you,
Brad Lyons
www.howavl.com
Old 09-29-2009, 02:28 AM
Mark Ziebarth Mark Ziebarth is offline
I just reviewed the MC Control and tried it with Pro Tools and Logic. HUI is a bit of a problem in three ways I think:
-You can only control four plug-in parameters per page although you have eight encoders. With stereo plugs you only have two if there are controls for the left and right side.
-Fader locking doesn't work with Pro Tools.
-Sadly you can't combine a MC Control with a Command|8.
But the Soft Keys help a lot for editing and navigating through Pro Tools.
Kind regards
Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control
MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate
Avid Digidesign Control|24 and Sterling Modular Desk Console for Control 24-Separate relaxo Buy & Sell 3 09-05-2013 07:05 AM
How to control plugins applied to audio files with Artist Control ozu Artist Series 3 04-01-2013 02:36 AM
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
D-Control Es32 Control Surface No Sound from Headphone outputs mark007 Pro Tools TDM Systems (Mac) 0 02-08-2012 07:03 PM
Mackie Control Universal or Tascam 1082 for control surface? anders Pro Tools TDM Systems (Mac) 5 05-28-2007 06:12 AM
