H/W Buffer Size Error Message (-6085)
I am having a new issue popping up during playback. This happens every time I play any project, whether it is a somewhat complete song or simply a click track. The song stops and a error message pops up.
Note The audio device buffer underflowed. If this occurs frequently, try decreasing the "H/W Buffer Size" in the Playback Engine or remove other devices from the audio firewire bus. (-6085). I tried decreasing the buffer size in the playback engine to its most minimum setting and the same error occurs. I've been using my digirack 002 for a long time, and I've never had this issue before recently. On Monday of this week, I called Digidesign about my machine acting oddly, and I was overnighted a new power harness which I installed on Tuesday (which in my opinion was awesome customer service - way to go Paula and Digi!), and was very excited to begin recording again, but now this issue has come up. I've tried to search the forums regarding this issue and have come up with no results for (-6085) and a broad selection of threads and topics if I search by "H/W Buffer size" or other parts of that error message. I'm currently using ProTools LE 7.1 SiSoftware Sandra System Host Name : PAUL User : Paul Fleck Workgroup : MSHOME Processor Model : Intel(R) Pentium(R) 4 CPU 3.00GHz Speed : 2.99GHz Performance Rating : PR3741 (estimated) Cores per Processor : 1 Unit(s) Threads per Core : 2 Unit(s) Internal Data Cache : 8kB Synchronous, Write-Thru, 4-way set, 64 byte line size, 2 lines per sector L2 On-board Cache : 512kB ECC Synchronous, ATC, 8-way set, 64 byte line size, 2 lines per sector Mainboard Bus(es) : AGP PCI IMB USB FireWire/1394 i2c/SMBus MP Support : 1 Processor(s) MP APIC : Yes System BIOS : Intel Corp. RL86510A.86A.0061.P09.0308281850 Mainboard : Intel Corporation D865PERL Total Memory : 2GB DDR-SDRAM Chipset 1 Model : Intel Corporation 82865G/PE/P, 82848P DRAM Controller / Host-Hub Interface Front Side Bus Speed : 4x 200MHz (800MHz data rate) Total Memory : 2GB DDR-SDRAM Memory Bus Speed : 2x 133MHz (266MHz data rate) Video System Monitor/Panel : Plug and Play Monitor Adapter : NVIDIA GeForce 6800 GT Physical Storage Devices Removable Drive : Floppy disk drive Hard Disk : ST380022A (75GB) Hard Disk : WDC WD800JB-00FMA0 (75GB) Hard Disk : Maxtor OneTouch II Disk CD-ROM/DVD : ATAPI CDROM 48X (CD 48X Rd) CD-ROM/DVD : HP DVD Writer 200j (CD 32X Rd, 12X Wr) (DVD 4X Rd) Logical Storage Devices Hard Disk (C:) : 75GB (37GB, 50% Free Space) (NTFS) HP_PAVILION (D:) : 69GB (41GB, 60% Free Space) (NTFS) Reason Adapted (F:) : 230MB (CDFS) CD-ROM/DVD (G:) : N/A 3.5" 1.44MB (A:) : N/A Record Disk (E:) : 279GB (276GB, 99% Free Space) (NTFS) Peripherals Serial/Parallel Port(s) : 1 COM / 1 LPT USB Controller/Hub : Standard Universal PCI to USB Host Controller USB Controller/Hub : Standard Universal PCI to USB Host Controller USB Controller/Hub : Standard Universal PCI to USB Host Controller USB Controller/Hub : Standard Enhanced PCI to USB Host Controller USB Controller/Hub : Standard Universal PCI to USB Host Controller USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Composite Device USB Controller/Hub : Generic USB Hub FireWire/1394 Controller/Hub : OHCI Compliant IEEE 1394 Host Controller Keyboard : HID Keyboard Device Keyboard : HID Keyboard Device Mouse : HID-compliant mouse Human Interface : HID-compliant consumer control device Human Interface : HID-compliant device Human Interface : HID-compliant device Human Interface : USB Human Interface Device Human Interface : USB Human Interface Device Human Interface : USB Human Interface Device Human Interface : USB Human Interface Device Power Management AC Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP/2002 Home 5.01.2600 (Service Pack 2) Network Services Adapter : Linksys Wireless-G PCI Network Adapter with SpeedBooster Performance Tips Tip 2546 : Large memory modules should be ECC/Parity. Notice 5901 : CD 1x= 150kB/s; Exercise caution when comparing measured versus published ratings. Notice 5902 : DVD 1x= 11.08Mbps Exercise caution when comparing measured versus published ratings. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. Any advice would be most graciously appreciated. Thanks, Paul http://www.myspace.com/thisfaintmemory |
Re: H/W Buffer Size Error Message (-6085)
Are you using the built in FW port on this computer, or a 3rd party FW card? If you're using a card, which one, exactly?
Usually this error is caused by an incompatible FW chipset - using a compatible FW card usually fixes it. Is your computer custom built or is it a brand name? |
My computer is custom built. Hope that helps |
Digi 002 FW HBA Compatibility Info |
Here in hungary I cannot buy the siig card. Will a texas instrument chipset firewire card do the job? Or can you recommend some more cards or brands which are known to be good?
TD
my blog:Tamas Dragon |
Increase Buffer Size Error Message | chillax69 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 21 | 01-07-2008 08:21 AM |
HW buffer size error message | jrbanjo | Pro Tools M-Powered (Mac) | 2 | 12-17-2007 10:49 AM |
buffer size error message | lionstudios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-14-2006 03:53 PM |
buffer size error message | 124cas | Digidesign Hardware & Software | 2 | 09-24-2001 05:18 PM |
re: buffer size error message | way2slo | Digidesign Hardware & Software | 0 | 09-15-2001 12:49 AM |
