Surround Panner and D-COMMAND?
Can you use the surround panner with D-Command?
Thanks |
Re: Surround Panner and D-COMMAND?
That would be a 'no' - it only works with D-Control.
What I'm pushing for with the Digi guys I know, is to have the capability to disable the rear L-R panner in the Pan Window (Opt-click maybe?). If that panner is deactivated, it would leave the front panner to handle the rear as well, giving you X-Y panning. Two panners, L-R and F-R, can be mapped to the two knobs on the D-Command. With X-Y panning, you can pan to any point in the surround field with just the two knobs. I have joysticks available on the large format console I use, but I hardly use them because I can switch the panners on the channel strips to X-Y, which makes it easier to do multiple panning tasks on each pass.
Mark Ettel C.A.S. |
Thanks for the info. Can you use a third party surround joystick to control this in PT? and if so can you rec. a good one to use?
Thanks |
D-control surround panner use with D-Command? | dicky.chan | ICON & C|24 | 0 | 08-19-2013 08:50 PM |
Sluggish surround panner? D-Command | Kristo Kotkas | ICON & C|24 | 3 | 04-01-2013 12:06 PM |
Surround Panner Option with Command 8 | KCMJace | Post - Surround - Video | 0 | 01-08-2007 02:56 PM |
Surround Panner options for D-Command?? | SteveBorne | ICON & C|24 | 5 | 04-15-2006 12:45 AM |
surround panner | propeler | Post - Surround - Video | 6 | 03-16-2004 05:02 AM |
