Old 08-16-2004, 09:28 AM
Justin1524 Justin1524 is offline
Default NI Battery 1.3.2 and Protools 6.4
I can't find a way to route individual drums to individual aux input or audio channels in Protools 6.4 using the NI Battery 1.3.2 plugin. I tried creating a VST version of Battery and using the Plogue Bidule Beta to route audio but could not get Bidule to appear as a plugin in Protools 6.4. It's maddening that NI Battery does not provide this essential feature.
I'm looking for an easy drag and drop drum sampler (like Battery) where I can assign individual drums to individual tracks so I can eq them etc. I thought of ReDrum in Reason but this doesn't seem to have a way to route audio the way I want. Also in ReDrum I can't even map midi keys to the drums which blows.
Also, why is every sampler I come across RTAS? Is a TDM sampler possible? - I have all this DSP available on my expensive Protools cards - why can't they be used for sampler plugins? Thanks.
Justin (Proud Pro Tools Ultimate PERPETUAL license owner)
Admin
www.elevenrackpresets.com
Studio: 2021 Mac Studio Ultra M1 20 Core CPU, 48 Core GPU, 64GB Ram, 4TB SSD boot | Pro Tools Ultimate 2022.12 | PreSonus Quantum 4848 interface| MOTU 112D interface | Digi PRE, FR OctoPre MKII, Mackie Onyx 800R, Panasonic WZ-AD96M (x2) and DA7, Eleven Rack, Apogee Big Ben, Mercury, Rode K2, Slate VMS ML-1 (x2). Laptop: Dell Inspiron 5559, i7-6500U 2.6Ghz, 16 GB RAM, 15.6" 1920x1080 1TB SSD
Old 08-16-2004, 09:31 AM
Vaphoron Vaphoron is offline
Default Re: NI Battery 1.3.2 and Protools 6.4
Unfortunately there isn't anything that can do what you want inside of Pro Tools right now. NI and Digi are well aware that this is a problem and are working to solve it.
- Jason
Old 08-16-2004, 11:14 AM
Thanks for replying but man that really is so bad. Sometimes I wanna return to Protool 5.3.1 on OS 9 but I'm too committed at this point to Protools 6.4. I hope a fix comes soon.
Admin
Old 08-16-2004, 11:23 AM
pk_hat pk_hat is offline
You can absolutely map keys to you drums in ReDrum. The first slot corresponds to C2, and then upwards for the next 9 slots.
www.myspace.com/krou
Old 08-16-2004, 02:09 PM
mindnoise mindnoise is offline
HI have you read this for your Plogue problem?
http://duc.digidesign.com/showflat.p...rt=&PHPSESSID=
I just use Battery this way and it works flawless here.
regs
last: PT11.3.1
Old 08-16-2004, 02:56 PM
Infa Infa is offline
Hi Justin1524, hey, wouldn't it be the same/easier/more solid anyway to just solo each drum sound you want to go to another seperate channel, and "record" it to another audio track, then use your eq'ing and settings on it, since it will be on its very own audio track... Since you said you wanted to just "route" it to another channel anyway,,, wouldn't that just take up another track as well, so you might as well just have it as real audio on its own track... Then do that for every sound on your drums in Battery, then just remove Battery, and all Midi tracks corosponding to free up some space since you wouldn't need them anymore on that pariticular song once you "tracked" out all the drum sounds..... and then you got all your drums the way you want them, but even more solid, because its real audio that doesn't have the inconsistancies of Midi and Battery.... Plus of coarse the ability to address different settings/eq's/compression/and effects to each and every different drum sound seperately....
Don't know,,, maybe/hopefully this helps
Old 08-16-2004, 10:13 PM
Vaporhead Vaporhead is offline
You can use the NN-XT sampler in REASON and have as many separate outputs, thru REWIRE, as you want.
Protools 7.4 and Battery 3 godzflava71 Pro Tools M-Powered (Win) 1 02-07-2009 11:20 PM
Setting up Battery 3 with Protools Le 7.3 rhythmg Virtual Instruments 0 03-08-2008 03:13 AM
Protools & Battery Nicholasguitar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-26-2008 12:59 AM
recording battery into protools chardly Tips & Tricks 28 04-03-2006 04:39 PM
ProTools LE, Digi002, and Battery DLawshea Digidesign Hardware & Software 0 07-30-2003 01:22 PM
