Old 05-12-2022, 08:59 AM
lampmusic lampmusic is offline
Default Virtual instrument freezing?
Sorry if this has been addressed:
This is most frequently occurring when doing a bounce with Garritan player (CFX Lite), but I've also had it happen on Air Xpand.
After doing a bounce the VI will not play anymore. I have to deactivate the VI and then reactivate and then it's fine until after the next bounce.
Macos 12.3.1 and the latest version of Pro Tools, although it happened with the earlier versions.
I don't remember this happening on Big Sur
Running Pro Tools 2021.12
Main System 2020 M1 Macbook pro 13 inch / 16MB Ram / 1TB SSD / Big Sur
Future System 2021 14inch M1 Pro / 16MB Ram / 512 / Monterrey
Old 05-18-2022, 01:50 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Virtual instrument freezing?
Just tested with XPand on my system and the VI is still working after a bounce. Not sure if it's a Big Sur issue or not - I'm on Catalina.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 05-19-2022, 05:26 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
I have found that as my (M1) CPU usage rises, MIDI playback is the first thing to suffer. Not that the system is overloaded but if I have a load of plugins running then MIDI tracks can stop playback. If I disable the plugin which are high in CPU usage, VI tracks start to play once again.
Maybe this is a similar issue to the one you are experiencing?
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Horrible freezing/intermittent lagging when using virtual instruments inside PT stevenkwlee Pro Tools 2018 6 05-28-2018 02:33 PM
Freezing all outputs of a multichannel instrument track causes -9400 error 2018.1 noiseboyuk Pro Tools 2018 7 01-29-2018 12:48 AM
Boom Virtual Instrument was "Unauthorized" during virtual instruments download Singer1212 General Discussion 1 12-29-2014 11:10 AM
Virtual Instrument help! madgt621 Virtual Instruments 2 04-06-2010 05:57 AM
Lag when using virtual instrument... onebigtrip 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-22-2008 10:47 AM
