Carbon and Eucon, S3 and AVB??
Hello! What’s the latest on compatibility with these technologies and Carbon/PT Ultimate?? Thanks!!
Armando |
Re: Carbon and Eucon, S3 and AVB??
What's the question? Carbon/S3/AVB all work well with a compatible Apple computer. Eucon works well on both Apple and Windows computers. AVB doesn't work on any Windows computer yet(sadly). Eucon allows the S3 to act as a control surface on most any system(just not as an interface). What did I miss?
Armando |
Its good to investigate everything, but I'm still not sure what the question is. Maybe it would help if you describe your needs and your budget
FWIW I don't think there will be a way to combine the AVB part of the S3 with the Carbon in any meaningful way; first, only a single Carbon is supported with the Hybrid Engine, and the S3 uses an older AVB packet format.
https://lukehoward.com/ |
True. But S3 can still act as a Eucon control surface with Carbon as the interface.
What about adding an AVB switch like the MOTU product?
Armando |
I would dig thru the Carbon manual for that. I suspect that AVB switches are not approved, but I could be wrong. I believe I have read that to use Carbon AND S3, Carbon would connect to the Ethernet port and S3 would connect to a thunderbolt port with the proper adapter.
Dominic EDIT: Here it is. Quote:
Eucon 3.2.2 installer error + firmware downwards compatible with eucon 3.1 | deauditievedienst | Artist Series | 2 | 07-14-2021 09:33 AM |
Updated to Eucon 3.6 and lost all my custom Eucon commands | bassmagnetic | Avid S1, S3, Dock and Control App | 0 | 04-18-2017 10:09 AM |
EuCon suddenly broken - Eucon client can not access the bonjour service | noiseboyuk | Artist Series | 0 | 04-12-2016 12:34 PM |
