Old 12-22-2020, 04:53 AM
DrewHarrison DrewHarrison is offline
Default Lock Marker Locations - Possible?
Is it possible to lock marker locations in place so they can't be moved accidentally?
Pro Tools 2022.12.0
Mac Pro 2019
OS X Big Sur
Old 12-22-2020, 09:14 AM
Sonopolis Sonopolis is offline
Default Re: Lock Marker Locations - Possible?
Well you can hide the marker ruler, but then you don't see them either
Old 12-25-2020, 02:08 AM
That's a no go.
Pro Tools 2022.12.0
Mac Pro 2019
OS X Big Sur
Old 12-29-2020, 12:00 PM
If you are working in Bars|Beats, then you can set the Memory Location Time Properties Reference setting to Absolute, rather than Bar | Beat. This will stop the marker from moving when there is a change to the tempo or meter map. But I don't think there is a way to lock them the way you can lock a clip.
Scott Gatteño
Old 05-14-2022, 01:05 PM
AlexLakis AlexLakis is offline
Bumping this as I am still getting used to my vertical mouse and half the time I click on markers they move accidentally.
Old 05-14-2022, 02:46 PM
BScout BScout is offline
You can't lock them like audio clips or video.
That's the end of that.
Old 05-15-2022, 05:54 PM
Hiding the Marker lane and showing the Memory Locations is the closest to a solution for the foreseeable future(but its a nice idea)
Old 05-17-2022, 10:57 AM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
No, but a workaround would be creating "marker tracks" and placing clip groups on the timeline. You can lock those. You can set the track to tick based if you want it to adjust to music mapping.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 05-19-2022, 03:25 AM
What Ryan said! Due to the limitations of Markers in PT we use marker tracks in post production all the time. You can have multiple ones, you can use audio or MIDI tracks, you can use empty Clip Groups or empty consolidated audio clips (the later can be exported as text), you can lock them, colour code them etc, you can even make the tracks inactive to safe some CPU power.
To turn Markers/Memory Locations into markers on a track, you can set the Grid to Memory Locations and use the Separate Clips-> On Grid command from the Edit menu.
Quick ways to rename Memory Locations in Memory Locations Window? tomfarleymusic Pro Tools 2020 3 05-09-2020 07:12 AM
shortcut needed: tab next marker/ prev marker Sir Hannes Getting Started 7 03-28-2018 09:01 AM
Keyboard shortcut for jumping from marker to marker... shotgunndunn macOS 1 11-28-2012 07:45 AM
Trying to set bar/beat marker, tempo marker won't conform maitredebas Pro Tools M-Powered (Win) 0 07-31-2009 07:31 PM
Snapping Regions to Marker Locations MidiMe Tips & Tricks 6 01-02-2005 12:11 AM
