Embedded rig settings
Hi folks!
I will try to explain how I record with my 11 and then you tell me how I'm not doing it right :) I always do 2 tracks: one with the input set to 11 rig and the other to guitar in. The rig is stereo and the guitar in is dry mono. I tell 11 in user settings to embed the 11 rack settings into the stereo rig channel. When I try to load settings the option simply isn't there but the the little e is on the track! This has worked previously and has me slightly concerned I may have done something wrong. Any ideas? Questions? Procrolamations of love? |
Re: Embedded rig settings
How are you trying the load the rig? Right Click the track and choose 'Load Rig Setting'? What exact version of Pro Tools are you using (8.0, 8.0.1, 9.0.2 ect....)
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
I do believe 9.0.6 - essentially the latest 9.0.X version I do believe.
I used to be able to right click and the option to load rig settings was there :) Thanks Ben, you are highly reliable! |
If you know the name of the track with the embedded setting (which is easy to find out by looking at the name of the track) you can load the Rig setting from the Eleven Rack Window as well from the drop down where you choose a rig.
I've found that at times when I open the 11R editor window and go to user options>embed settings from, the selection has changed from where I had set it last time I used it.
And yet at other times, it seems to default to the setting that was last used...Eleven Rig L/R (my usual setting) ......... weird. I too have had the problem of right clicking a region and having no 'Load Rig setting' option but I found out it was because I'd assumed/expected the user options>embed settings from choice I'd made previously would still be there when in fact it wasn't. Now before I record, I always check the setting whether or not I see the 'E' on the 11R track.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Hey that works!
Thanks Ben! Ya I've seen it switch too but I related that to different projects and the learning curve. I'll note it next time and look for anomolies, Cheers!! |
Embedded Rig Settings in PT11? | NoiseRoom | Eleven Rack | 4 | 07-13-2013 02:00 PM |
Loading embedded rig settings | Stig Eliassen | Eleven Rack | 6 | 05-05-2013 02:52 AM |
no more embedded waveforms? | Polaris | Post - Surround - Video | 3 | 07-15-2011 10:39 AM |
Embedded Settings Question... | Tom Hartman | Eleven Rack | 2 | 05-13-2011 12:12 PM |
