Old 10-01-2021, 12:14 PM
crnds crnds is offline
Default MIDI in 420 Hz
Hi everyone!
I'm running Vocal Synth in Pro Tools 18 in a Live situation. I need to set global tuning to play with a baroque pipe orgue. This one is tuned at 420 HZ. I need to send 420 Hz midi information from my keyboard to use the midi mode of this plug-in (vocoder). Any ideas?
Thank you very much!
Old 10-30-2021, 04:44 PM
Default Re: MIDI in 420 Hz
Hmmm, this might be not possible, but I would start with Midi Realtime Properties and see if you can enter a pitch change(maybe via a pitch wheel adjustment)?
Since Ab is 415.3 Hz, maybe a half-step transpose would work(given its less than 5 Hz off of your desired 420 Hz)?
dr 770 (boss dr rhythm 770) as midi controller/midi output to 11r midi input yellow Eleven Rack 1 05-04-2012 03:33 PM
003 midi ports not there in midi studio setup? Unable to record midi now? TREBLEBLEED 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 12-22-2009 12:06 AM
MIDI Questions On IMPORTING MIDI & Recording MIDI Pro Tools LE 7.4 Michaeldante MIDI 3 03-27-2009 05:42 PM
USB midi vs. din midi-(the old style midi connector) Ling Pro Tools M-Powered (Win) 1 02-19-2009 02:15 PM
