Old 06-12-2022, 11:38 AM
senghor senghor is offline
Default PT says "you need t.... 48 khz?
when I try ti open a session PT says "you need t.... 48 khz?
I don'u the cause. WHAT's happening-!!!
Win11 Pro
Intel i7-12700K @3,6GHz, RAM 32GB
UAD Apollo and pre-amps, Pro Tools 2023
lots of plugins
Old 06-12-2022, 12:26 PM
Default Re: PT says "you need t.... 48 khz?
Is that the complete message? Guessing(since you give nearly zero info on the setup) that you are letting Windows use your interface as its default playback device, which means Windows is controlling the sample rate. This is why almost all Windows setups need Windows to use the on-board sound card as the default playback device. THis allows Pro Tools to control your interface sample rate.
Old 06-12-2022, 04:11 PM
Per the error message, "you need t.... 48 khz." So try that and see if it works. I can't guess what it is saying but it looks like it tells you what you need.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 06-12-2022, 06:34 PM
sw rec sw rec is offline
What ALBEE said.
"Digidesign Midi I/О" in "ProTools 10HD" in "OSX Maverics" electra1006 MIDI 0 06-18-2018 05:46 AM
Keyboard Shortcut for "Track List", "MIDI Editor Pane", and "Clip List" EdgarRothermich Pro Tools 12 2 10-04-2017 02:18 PM
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... leon777 Pro Tools TDM Systems (Mac) 21 10-15-2002 12:00 AM
