Old 05-29-2022, 01:28 PM
SpringBreak's Avatar
SpringBreak SpringBreak is offline
Default Backing up to the Avid Cloud - error message
I added cloud storage backup today, and when I tried to sync my local file I get the following error:
Assertion in "/Users/autobld/gitlabci/PT/release/2021/r3/ProTools/NewFileLibs/Sys/Sys_FileType.cpp", line 126.
I have to force quit pro tools as the message persists regardless if I try to cancel.
This is the file from the editor, if I create a new empty file and store it, doesn't seem to be an issue.
I'm using 2021.12
Spring Break Films
http://bloodpledge.us
Old 05-30-2022, 02:15 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Backing up to the Avid Cloud - error message
I’m not sure what you are trying to do here. When you say you are backing up your file from the editor, I’m guessing you have created a Pro Tools project and this project contains an audio file that you have imported? If this is correct, what is the file type you are importing?
I’ll also assume that when you say create a new empty file, you mean that you record a track in PT, and that newly recorded audio will upload fine?
The error mentions file type. If you are using default settings for a new project, your newly recorded file will be a wav file, which seems to work fine for you. Not sure what your imported file is, but first make sure to select the option to copy the file to the project folder when importing. If that doesn’t work, maybe try converting it to another format, like wav.
Will
System Details
Old 05-30-2022, 09:03 AM
Hi Will,
Thanks for your reply ~
Okay, sorry for no specifics...
My editor worked in Media Composer and gave me the final project in that format. I exported the audio as an AAF file.
When I import the file and work locally, all is well. But if I try to setup the project on the cloud (See attachment), I get the error message mentioned previously.
Spring Break Films
Old 05-30-2022, 09:59 AM
Why are you folks trying to use a cloud project at all? There are hundreds of posts on DUC about how broken/fragile these things are for basic stuff. And you are trying to do post/audio? Forget it.
And as for backup… unclear why you described it as a backup. A cloud project is *not* a backup of a session. So double forget it, this is not in the remotest way any sensible part of a backup scheme.(Although backing up *sessions* to third party cloud storage can be a good part of a backup strategy).
You folks could make a horror documentary about your horror movie… “How I killed a movie project trying to use Pro Tools cloud projects”.
Old 05-30-2022, 10:19 AM
Got it.
My day job is IT support and this is my first feature. It's often SOP to use a well established vendor's cloud service when backing up and collaborating. Integration...
Down the road, I plan on having another sound person look at the work.
Seemed like a logical choice. Avid is a well established company. Odd that this aspect has so many issues, as I found out.
Spring Break Films
Error message trying to move from ilok to cloud...any ideas? pic included H-man Pro Tools 2019 3 11-05-2019 10:28 AM
Avid Cloud Collaboration error jamalcom x Pro Tools 2018 1 06-30-2017 01:53 PM
Message for AVID - DAE ERROR -7401 Wavelabs Pro Tools M-Powered (Win) 0 01-16-2011 12:43 AM
