Structure 1.1 outs don't list on tracks I/O tabs
Following the PT210M manual I should be able to route channels from a single instance of Structure I've placed on an instrument track to a separate track fro each channel, but it doesn't. The I/O tab remains greyed out on all other tracks (Aux, audio) with no structure channels to select separately as input to record and mix.
Installed PT IEP on PT 10.2. ... reinstalled PT 10.2. Strike works fine and routes as expected just not structure. I also duplicated the same issue on two machines. ... Tried trashing prefs, etc, reinstalling PT but still frustrated. Is this a known issue? would appreciate some support as it was one of the main reasons for purchasing the IEP. Thanks, PT 10.2 MBOX Pro 1.0.16 ------------------- Mac Book Pro OS X vr 10.7.4, 2.66 Ghz Intel Core i7 8Gb 1067 MHz DDR3 |
Re: Structure 1.1 outs don't list on tracks I/O tabs
having same issue did you ever find a fix?
I did, but I tried so many things I can't be sure what exactly was the key to the solution. However, first thing is too completely uninstall the Structure free and remove all traces, trash prefs, DB's etc. Open PT and check its completely removed.
Install the full version of Structure and it should be fine. I did this on 10.2 and currently have a fresh install on a virgin machine for 10.3 so will post back if there are any repetitions of the issue and will log the fix. Hth |
Structure AAX Multiple outs? | 6lovemusic | AAX Plug-ins | 2 | 10-27-2013 04:46 PM |
Structure 1.1 Patch List | Kronos06 | Virtual Instruments | 2 | 01-06-2012 01:06 PM |
manually setting warp tabs/ deleteing multiple arp tabs | glideman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-22-2010 01:31 PM |
'Structure' does not appear on my plug-in list | HerbD | Virtual Instruments | 1 | 09-02-2007 02:51 AM |
Would the Line 6 POD pro SPDIF outs make the guit. tracks MIDI tracks? | Trash Man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-06-2000 08:40 AM |
