Old 11-05-2010, 10:11 AM
Russ5412 Russ5412 is offline
Default EZDrummer in PTLE 8.03
Hi guys, hope I'm posting in the right forum!
I'm using Pro Tools LE 8.03 (w/mbox2) in Windows 7 64bit. I've just bought EZDrummer and DFH and I'm trying to open it up in Pro Tools. I have done a search on the forum and tried a couple of things but I still can't find EZDrummer in the plugins menu in Pro Tools.
The installation works fine, i do a custom install into C:\Program Files (x86)\Common Files\Digidesign\DAE\Plug-Ins... Do i need to use a VST to RTA adapter? If so how do i do this?
Many thanks in advance for any help!
Russ
Old 11-06-2010, 10:56 AM
Alan Z Alan Z is offline
Default Re: EZDrummer in PTLE 8.03
I use EZ Drummer and PT M-Powered 8.0.x and it works fine. Your last sentence has me wondering if you installed the RTAS versions of EZ Drummer and DFH or if you possibly accidentally installed the VST version instead? If the latter, then re-run the installer and install the RTAS version and you should be good to go. Otherwise I'm not sure what to say to help you.
PT 12.8.2
macOS Sierra 10.12.6
iMac (27-inch, Late 2012)
3.4 GHz Intel Core i7
16 GB 1600 MHz DDR3
Interface Focusrite Saffire PRO 24
EZDrummer and PTLE Vmann Eleven Rack 13 07-10-2011 11:55 AM
PTLE and EZDrummer - midi mapping ? Philippe Delanghe MIDI 10 03-01-2010 12:31 PM
Ezdrummer and PT8 jimidalliance The Drum Room 4 11-29-2009 12:05 PM
EZdrummer and PTLE rabs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-15-2007 02:18 PM
EZDrummer with PTLe 6.4 rems 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-31-2007 05:22 AM
