Need help ! Installing VSL Opus 1 EXS 24 to run within Structure.
Hi Everyone !
I never used EXS 24 sample libraries within Structure, and I have a VSL Opus 1 library, that so far I used within Giga Studio on a separate PC computer. I know that Structure supports EXS 24 format. My main problem is that I have no idea how to properly install the Opus 1 EXS 24 library on my Sound Libraries external HD. So far I have just Structure factory Libraries, and Goliath Structure edition installed. During installation obviously both of these libraries created particular folders, and the entire path by themselves, and all I had to do was just to drag the contend of the DVD's into Samples folder. Now the task for me is to create from scratch the ( programs ? samples?) folders and somehow tell the Structure how to find these libraries. I'm a musician / composer- not a computer guru ( unfortunately), and I would really appreciate any detailed step by step info how to install these VSL EXS 24 library. Sincerely, Chris7514 |
Re: Need help ! Installing VSL Opus 1 EXS 24 to run within Structure.
What I do is set up a folder on an external drive similar to what you have already done for your other libraries and install the samples/libraries sounds int that folder.
Then, launch ProTools, create an instrument track, stick Structure in the track and open Structure. Then I use the browser in Structure to find the library, samples, sounds whatever. Works for me all the time.
PT 12.8.2 macOS Sierra 10.12.6 iMac (27-inch, Late 2012) 3.4 GHz Intel Core i7 16 GB 1600 MHz DDR3 Interface Focusrite Saffire PRO 24 |
Trouble installing Structure | ghostdroid | Virtual Instruments | 17 | 08-16-2013 01:31 AM |
help installing STRUCTURE | darkman2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-07-2011 04:45 PM |
Need help with installing Structure / Goliath - Structure Edition | soundslikeivo | Virtual Instruments | 3 | 05-18-2010 01:04 PM |
Digi 003 rack - very high input gain with Beyer Opus 88 mic | zv yoda | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-02-2009 08:47 AM |
Installing Structure LE with Pro Tools 8 | FreqSabotage | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-15-2009 12:31 PM |
