Increase Hardware Buffer Size? issues! PLEASE HELP!
I have increased to maximum settings and still get a error everytime I hit spacebar. I have a brand new mac book pro with 2 GB of ram. my settings are:
H/W buffer size 2048 samples RTAS 2 processors CPU Usage limit 90% DAE Buffer: 1500ms (default) I cant bounce, record or even play for that matter. Anyone have any of the same problems..are my setting incorrect. I have tried everything. any help much appreciated. Thanks |
Re: Increase Hardware Buffer Size? issues! PLEASE HELP!
Hi there,
exactly the same here. 2 Days before it worked for a Day. Nothing changed , yesterday no chance, Mac Book Pro 10.5.2 4 GB Ram Intel Core Duo Thanks Jens |
Have either of you gone through the steps in the 'troubleshooting' sticky thread at the top of this forum?
What other steps have you taken? Have you searched the DUC for members with similar issues?
Where in the world is DJ Reggie? |
The wierd thing is that PT worked great with my G4 power book. It will not even run decently with the new mac book pro.
OS-10.4.11 2GB, 2.2 GHz Intel Core Duo PT-7.4 Its also weird b/c i had a friend with a G5 that had the SAME issues. plenty of needed hardware and the software will not operate correctly. It must be a setting or I must enable or disable something etc. Thanks |
check the steps for optimizing your pro tools. do you have airport turned off? Bluetooth?
iMac 2.4 Ghz 3 gig of ram Leopard 10.5.6 Boot Camp XP Pro Tools 8 Digi002 |
are you recording to an external drive? what is your chain?
What's the error number in the messages you're getting? |
I`m having the same problem here.
MacBook Pro 2.2GHz Intel Core 2 Duo 2 GB 667 MHz DDR2 Mac OS X 10.4.11 Pro Tools LE 7.4 MBox 2 Pro Lacie 160G external firewire HD |
"Increase Hardware Buffer Size" | MaKoRancid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-27-2007 08:10 AM |
Increase Buffer size/Decrease Buffer size? | kerick | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-28-2006 12:00 AM |
Increase hardware buffer size madness | sricabla | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-28-2006 08:54 PM |
Increase Hardware Buffer size | Kevin Taylor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 28 | 08-25-2004 05:43 AM |
increase hardware buffer size | Ricco | Tips & Tricks | 8 | 03-21-2001 02:47 AM |
