Re: DIGI: PLEASE FIX COREAUDIO DRIVER + PEAK!
bump
Hi guys,
I have a fix for this (in our driver). I'll see about getting it out to those who need it. Thanks, -Ted DAE Group Digi Engineering |
Wow, that would be fantastic! It's important to know that at least this is being worked on and addressed. Knowing it is in the works is often the difference between dumping a product and continuing to make it the center of a platform at a facility.
By all means, I would like to try a copy. I hope it is finalized and rolled into an official release as well. Thanks very much for seeking us out, Ted... -Brian [email protected] |
the AU support in protools would be nice thing, but i doubt that will happen...
Hey Ted, I would also like a solution to this problem. I've got a project that I was trying to use Peak on with my digi002 as the sound source and ran into the same problems everyone here has had... also including crashing with digi002 as a sound source.
Thanks, John |
Hey,
Did anyone hear anything about this fix for coreaudio? Thanks, John |
I'm not sure if my problems are related to difficulties you are experiencing in peak, however this does boil down to digidesign's core audio driver so I felt it would fit into this thread.
I have a fresh install of Panther 10.3.2 on a Tibook 667. I am running PTLE 6.2.3 on an MBox with more stability in terms of playback/record facility and overall robustness of the app than in previous versions. When I am running other apps, namely Reason and Logic, with the Digidesign Core Audio driver as the preferred driver they crash. Below are exerpts of the crash logs, 3 instances for Reason and one for Logic REASON: ------------------------------instance #1------------------------- Thread 12 Crashed: 0 <<00000000>> 0x00000000 0 + 0 1 ...idesign.DigiCoreAudioPlugIn 0x0525eafc _ZN19DigiCoreAudioDevice16DirectIOCallbackEP15IODr iverAudioPB + 0x74 (DigiCoreAudioDevice.cpp:136) 2 ...idesign.DigiCoreAudioPlugIn 0x0525e91c _ZN19DigiCoreAudioDevice22StaticDirectIOCallbackEP 15IODriverAudioPB + 0x30 (DigiCoreAudioDevice.cpp:58) 3 DirectIO 0x05688a20 0x567e000 + 0xaa20 4 DirectIO 0x05684de4 0x567e000 + 0x6de4 5 DirectIO 0x0568a7d0 0x567e000 + 0xc7d0 6 DirectIO 0x056898d0 0x567e000 + 0xb8d0 7 DirectIO 0x05689a28 0x567e000 + 0xba28 8 DirectIO 0x056aead8 0x567e000 + 0x30ad8 9 ??? 0x05855c30 _ZN12CLowIODevice14StreamCompleteEP7CStream + 0x208 10 ??? 0x0585c144 _ZN9RTRunLoop8TaskMainEPv + 0x15c 11 ...ple.CoreServices.CarbonCore 0x902c6f3c PrivateMPEntryPoint + 0x4c 12 libSystem.B.dylib 0x900247e8 _pthread_body + 0x28 -------------------------------instance #2------------------------ Thread 12 Crashed: 0 <<00000000>> 0x00000000 0 + 0 1 ...idesign.DigiCoreAudioPlugIn 0x0525eafc _ZN19DigiCoreAudioDevice16DirectIOCallbackEP15IODr iverAudioPB + 0x74 (DigiCoreAudioDevice.cpp:136) 2 ...idesign.DigiCoreAudioPlugIn 0x0525e91c _ZN19DigiCoreAudioDevice22StaticDirectIOCallbackEP 15IODriverAudioPB + 0x30 (DigiCoreAudioDevice.cpp:58) 3 DirectIO 0x05688a20 0x567e000 + 0xaa20 4 DirectIO 0x05684de4 0x567e000 + 0x6de4 5 DirectIO 0x0568a7d0 0x567e000 + 0xc7d0 6 DirectIO 0x056898d0 0x567e000 + 0xb8d0 7 DirectIO 0x05689a28 0x567e000 + 0xba28 8 DirectIO 0x056aead8 0x567e000 + 0x30ad8 9 ??? 0x05855c30 _ZN12CLowIODevice14StreamCompleteEP7CStream + 0x208 10 ??? 0x0585c144 _ZN9RTRunLoop8TaskMainEPv + 0x15c 11 ...ple.CoreServices.CarbonCore 0x902c6f3c PrivateMPEntryPoint + 0x4c 12 libSystem.B.dylib 0x900247e8 _pthread_body + 0x28 -------------------------------instance #3---------------------------- Thread 0 Crashed: 0 com.apple.audio.CoreAudio 0x907221c0 _ZltRK17HPPropertyAddressS1_ + 0 1 com.apple.audio.CoreAudio 0x9077703c 0x90720000 + 0x5703c 2 com.apple.audio.CoreAudio 0x90725f70 _ZNK16HPPropertyObject11HasPropertyERK17HPProperty Address + 0x28 3 com.apple.audio.CoreAudio 0x90727fa8 _ZNK8HPDevice11HasPropertyERK17HPPropertyAddress + 0x294 4 com.apple.audio.CoreAudio 0x90725968 _ZNK9IOADevice11HasPropertyERK17HPPropertyAddress + 0x16c 5 com.apple.audio.CoreAudio 0x9072c32c _Z39HPDeviceSettings_SaveControlsFromObjectRK16HPP ropertyObjectbmR14CACFDictionarybPKN16HPDeviceSett ings11ControlInfoEm + 0x74 6 com.apple.audio.CoreAudio 0x90745a70 _ZN16HPDeviceSettings16SaveToDictionaryERK8HPDevic ePKNS_11ControlInfoEm + 0x70 7 com.apple.audio.CoreAudio 0x907458b4 _ZN16HPDeviceSettings11SaveToPrefsERK8HPDevicePKNS _11ControlInfoEm + 0x20 8 com.apple.audio.CoreAudio 0x90745708 _ZN9IOAPlugIn12DeviceIsDeadEP9IOADevice + 0x134 9 com.apple.audio.CoreAudio 0x907454f4 _ZN9IOAPlugIn8TeardownEv + 0x3c 10 com.apple.audio.CoreAudio 0x90745478 _Z16HPPlugInTeardownPP28AudioHardwarePlugInInterfa ce + 0x28 11 com.apple.audio.CoreAudio 0x907453b4 _ZN22HALPlugInDeviceFactory8TeardownEv + 0x30 12 com.apple.audio.CoreAudio 0x9074534c _ZN9HALSystem15TeardownDevicesEv + 0x28 13 com.apple.audio.CoreAudio 0x907452d0 _ZN9HALSystem13AtExitHandlerEv + 0xa8 14 com.apple.audio.CoreAudio 0x907451c8 _ZN9HALAtExit13AtExitHandlerEv + 0x6c 15 libSystem.B.dylib 0x9002c8b8 exit + 0x58 16 com.apple.HIServices 0x92d46f28 _ZN16OpaqueICInstanceC1Ev + 0 17 Reason 0x01355508 0x1008000 + 0x34d508 18 Reason 0x01355478 0x1008000 + 0x34d478 LOGIC: Thread 13 Crashed: 0 <<00000000>> 0x39473abc 0 + 0x39473abc 1 ...ple.CoreServices.CarbonCore 0x902c6f3c PrivateMPEntryPoint + 0x4c 2 libSystem.B.dylib 0x900247e8 _pthread_body + 0x28 Now, I'm no expert at reading crash logs, nor do I code. But from looking at the logs, I can see the words "Direct I/O" amd "digicoreaduiodevice", indicating the Digi core audio driver is involved in the instability of the apps in some way. I am, or at least try to be for the most part, an end user that simply wants my hardware and software to work. It is my understanding that Apple developed core audio in conjunction with the other major audio developers (Steiny, Emagic, Digi, Yamaha to name a few) in order to bring a standard to the platform. Being that TDM/HD systems have their own subsystems for handling audio, bypassing Mac's core audio and effectively becoming their own platform, I would imagine the previously mentioned phenomenon to be quite acceptable. But LE being host based should, by all accounts, follow the rules set by the host. I really hope digidesign takes this core audio problem seriously, even if we didn't drop 7k on an HD core+I/O. I am awaiting delivery of a G5 and was planning on buying a Digi002 to complement the new computer. Maybe I should rethink that and keep the mbox around with the Tibook dedicated to protools, since it really is the best tool for editing audio, while running the G5 with another interface. Unfortunately, most users don't have the luxury to really do that and I would rather see working drivers myself. In any case, I hope someone reads this and can offer some kind of help. thanks konrad
G5 1.8X2/3gigRAM/Mbox/7.4 (retired) MBP C2D 2.4/4GigRAM/Mbox/8.0.1 iMac i7 3.4/16GigRAM/10.0.1 |
I've been unable to use Live in conjunction with Core Audio and my MBox. Nice little kernel panic hits my Tibook after a minute or so...
Routing through Rewire works though....anyone else having problems with Live and Core Audio??
Paul Peterson Sound Director The Old Globe San Diego, CA |
I am also having problems with the core audio card and my DIGI001. I'm having problems with Peak, Garageband and Sountrack. I'm pretty sure that if in the audioMIDI utilities my card read 8ch -16bit it'd be fine, but my DIGI reads 2ch - 32bit: this sountrack does'nt understand.
Any fixes on the DIGi core audio driver would be much appreciated. It would save having to buy a whole new soundcard. Thanks |
digi CoreAudio driver still supports 8 i/o only. Why? | Tobias Eichelberg | Pro Tools TDM Systems (Mac) | 2 | 01-03-2009 02:03 PM |
Uninstall Digi CoreAudio driver? | rockridge98 | Pro Tools TDM Systems (Mac) | 5 | 12-07-2006 09:40 PM |
Digi CoreAudio driver for MacBook | Dany | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-02-2006 09:10 PM |
Digi: What Benifit's are to Coreaudio Driver 6.7 ? | SoundEng1 | Pro Tools TDM Systems (Mac) | 1 | 11-15-2004 07:59 PM |
Digi: CoreAudio Driver loud pop | Mauro371 | Pro Tools TDM Systems (Mac) | 2 | 05-01-2003 09:18 AM |
