10.4.11 Quad core intel
Mbox2 pro For some reason every once in a while when I open protools I will get the grey curtain of death. also known as a curnal panic. this happened 5 times in the last 3 months. I have repaired my disk permissions a few times. every time I do I get a lot of things dealing with fonts.??? also previously I had a problem with the M box not playing audio. I had to unplug the firewire and then plug it ack once the light started blinking. that usually fixed it until i shut down or restarted. I haven't had that problem in a while but I thought it might be related. |
This could be caused by any number of things - any software or hardware on your computer could be a factor. Bad RAM sticks, loose cable connections, software incompatibilities, corruption, etc.
Can you post more complete system info - Pro Tools version, attached peripherals, which of the General Troubleshooting steps you've tried, etc. You may want to consider a clean OS and Pro Tools install, to reduce the possibility of OS corruption being a factor. You could also post a crash log - it may have some info about what caused the kernel panic. |
Ok i have version 7.3.1
firmware version 2006-06-23 04:33:45 -0400 I was copying files to the same drive or up loading files to an FTP site. when i opened protools the system would crash in the initial start up,( The screen with the PT logo and loading plugins)not when it was opening the session itself. I am running a Quad core Intel with 2x 500 GB of hard drives and 4 GB of RAM. Could the fact that the M box was giving me play back issues before have anything to do with this. the odd thing is it did it yesterday and i wasn't even opening a session, i was just copying a lot of file to be burned and loading files on to an FTP site |
Protools crashes on opening sessions | Etienne_C | Pro Tools TDM Systems (Mac) | 2 | 07-29-2010 07:31 AM |
protools crashes while opening | straight cash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 01-23-2007 11:04 AM |
ProTools LE 6.4 crashes when opening a session | olguitar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-07-2004 05:13 PM |
ProTools crashes when opening from firewire | Nathanael | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 02-02-2004 12:44 PM |
Opening new session crashes Protools | Studiomeijer | Pro Tools TDM Systems (Mac) | 1 | 12-21-2003 05:38 AM |
