Old 05-25-2022, 10:59 PM
harvey bushell harvey bushell is offline
Default Using .dsh file
Hi.. I'm a mostly retired FOH sound tech somewhat unfamiliar with the intricacies of using the SC 48 software. I can mix on one with no issues and set one up during soundcheck from the console's surface interface, one channel at a time but find it time consuming. I've downloaded the VENUE software app, latest version I believe, and through mostly trial and error and reading the instruction manual have created a 57 kb .dsh file that I'm hoping to bring into a venue next week to save setup time during soundcheck.
I created a 22 channel mix, set up basic parameters like HPF, EQ, O/P, Dynamics, channel names but not any house/mon EQ, FX or aux sends which I would like to leave up to the existing setup on the console at the club I'm visiting... I've used these before and like them so I don't want to change them and need his aux/fx/mon sends as they exist.
I believe the .dsh file I set up has only the things I want but am not sure if that file will be useable when I get to the club. I only want to save the parameters I've created but leave all the other things in the house console as default. Hope that's clear. See the attached pic for the parameters I believe I've saved on the file. Will this do what I'm hoping it will? And I hope this question is clear.
When creating a template.ptxt file is it a stand alone self contained file? xrekcor Pro Tools 2018 9 12-23-2018 11:14 PM
pro tools 8 le quits unexpectedly while changing from file to file. rob gracia stone macOS 1 11-12-2013 01:09 AM
'save a copy as' damaged a file - file repair advice? Artysan Pro Tools TDM Systems (Mac) 8 03-26-2011 06:14 PM
Question: Converting an audio drum file to a MIDI file? ctyelvis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-18-2010 06:56 AM
Exporting Mono File to a Stereo Interleaved File Mt.Everest Pro Tools TDM Systems (Mac) 3 03-13-2008 04:01 AM
