Old 05-09-2011, 09:30 PM
ecki ecki is offline
Unhappy Noises by changing gain on a AVID PRE
I´ve got this problem with the PRE: If I change the gain in PT´s Mic Preamp (on an audio track) I hear a noise! I won´t believe that this is true! Is there any body there with the same problem? The PRE is controlled via a MOTU MIDI-Express 128.
Old 05-09-2011, 09:50 PM
Top Jimmy's Avatar
Default Re: Noises by changing gain on a AVID PRE
That's as expected since the PRE uses a stepped attenuator for the gain.
If you want to be able to smoothly ride the gain while recording, you have to route the input through an aux channel before the audio track and use the aux fader for gain riding.
James Cadwallader
Old 05-09-2011, 10:30 PM
Thank you ;D
Old 05-10-2011, 04:14 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Plus they coarse-change in 3db increments... I also use Grace remote pre's. still jumps (3db) but less of a click. I use these with a C/24 controller. for tracking I set up like a traditional split console.
1-24 aux inputs for riding (as mentioned above) Bank 2, 1-24 for CR mix & cues.
Old 05-10-2011, 10:13 AM
Top Jimmy's Avatar
When using the Icon in this fashion, there is an input button on the channel strip that would put the input fader on the lowest rotary encoder above the output fader. This could then be flipped down to the main fader as desired.
James Cadwallader
Old 05-10-2011, 12:50 PM
Okay, I see, this may be the only way. Flipping in D-Control is a very cool feature, we´re using it very often.
Changing email address for Avid account Tyderian Tips & Tricks 6 11-22-2013 09:18 AM
Changing gain to a selected region in playlist davinci650 Pro Tools M-Powered (Mac) 0 08-16-2007 09:14 AM
OMF files and gain automation from PTLE and Avid Xpress Pro mangione Post - Surround - Video 3 04-19-2007 09:08 AM
PT and Avid gain issues Lowdbrent Pro Tools TDM Systems (Mac) 5 06-01-2006 07:33 PM
Changing gain without adding dither sburgess Pro Tools TDM Systems (Mac) 10 10-02-2001 05:29 AM
