Old 06-01-2021, 05:51 PM
tchmura tchmura is offline
Default Too Many Tracks
At roughly 120 tracks, it looks like I've reached the limit. I get an error message: "Too many Tracks entered for the current Pro Tools configuration. The maximum value will be substituted."
Is there any way around this?
Old 06-01-2021, 07:20 PM
Philthy Philthy is offline
Default Re: Too Many Tracks
Yeah
Upgrade to ultimate,
or print submixes
I started on 4 tracks
Phil Mann
Silk City Music Factory - CT Recording Studio
Old 06-01-2021, 09:09 PM
Sardi Sardi is offline
What are you doing that requires 120 tracks? IOW - do you need 120 simultaneous tracks? If not, make the ones you don’t need inactive.
I frequently see dozens of muted tracks in sessions and when I query it, I get told they’re alt takes or tracks that didn’t make the cut. Make them inactive and free up resources.
Unless you’re working in post or scoring, 120 tracks is a lot of channels.
Old 06-02-2021, 03:05 AM
Reml@P Reml@P is offline
Originally Posted by Sardi View Post
IOW do you need 120 simultaneous tracks? If not, make the ones you don’t need inactive
Pretty sure that the current version of Pro Tools tops out at 128 mono tracks whether they are active or not. In the past making tracks inactive was a way around this but not anymore.
Feel free to correct me if I’m wrong.
Old 06-02-2021, 04:33 AM
Of course. I was saying 120 as that’s what the OP mentioned.
But you can still free up resources by making them inactive. If you have 130 tracks, 2 won’t play. If you make another 2 inactive, they will.
Old 06-02-2021, 05:54 AM
Yeah you’re not hearing what I’m saying. In the latest version of PT vanilla it’s 128 tracks maximum. Doesn’t matter whether half of those are inactive or not. You can’t add anymore than 128.
At least that’s how it was last time I did a post session.
Old 06-02-2021, 06:38 AM
JFreak's Avatar
JFreak JFreak is online now
^^ this.
Alternative takes should be taken on playlist on same track.
Janne
Old 06-02-2021, 10:47 AM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
I usually have stacks of 6 or 8 background vocals per part. What I do after comping/tuning is to bounce each part down to stereo. That way I end up with 3 stereo tracks instead of 24 mono. I do the same with keyboard stacks and any other instruments that would benefit from that and make my life easier while mixing.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 06-02-2021, 04:30 PM
Rudeness aside, I stand corrected.
I just tried and you’re right, you can not add anymore than 128 tracks regardless of whether you make some inactive. It physically won’t allow you to add any audio tracks after you have 128 in your session.
Does anyone know when this behaviour changed? Is it documented anywhere? This was definitely not the case in the past. Is it a bug or a new implementation? If the latter, why?
Old 06-02-2021, 04:56 PM
BScout BScout is offline
Key Features
https://www.avid.com/pro-tools/comparison
First line
(note the limits for all types of tracks listed in this comparison)
No audio in frozen tracks after export selected tracks to new session PierrevC Pro Tools 2018 4 11-14-2018 03:33 PM
PT10: Import tracks with overlay+match tracks not working Frank Kruse Post - Surround - Video 3 12-02-2011 09:06 AM
OPEN WITH TRACKS INACTIVE???---snow leopard is biting my foot (& tracks) stormmusic Post - Surround - Video 2 10-09-2009 04:43 PM
Instrument tracks VS Aux tracks+MIDI tracks mixaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-03-2006 04:08 PM
Would the Line 6 POD pro SPDIF outs make the guit. tracks MIDI tracks? Trash Man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-06-2000 08:40 AM
