Old 02-03-2005, 05:56 PM
Laurence w schuberth Laurence w schuberth is offline
Default audition problems
Hi all
I bet this one is finger prob buts its got me!!
tools 6.4 hd, mac g5 2.5
Using adat out from 96 into an 03d , everything works great but can seem to get audition to
work on audiosuite plugs via the adat link.
can assign to analog 1-2 and it works ok, but thats all.
Any ideas would be great
cheers
Larry
Old 02-03-2005, 08:57 PM
SessionKat SessionKat is offline
Default Re: audition problems
Hi all
cheers
Larry
What's your I/O path choice for audition in the I/O Setups?
-tv
Tim vdB
Avid Audio
"There's a fine line between stupid and clever."
Old 02-06-2005, 05:56 PM
Sorry ,weekend got in the way
Ok so I have my 96io and a sync io hooked up to a yammy 03d via lightpipe.
My only in/out that I have active is channels 9-10 (adat 1-2)
I have them set for Main Out Metering, default output and audition output.
I get nothing on the 96 meters and no sound when using preview
If I make a new path and make it output 1-2 (analog) I get meters and souned from output 1-2
Any help would be great
Cheers
Larry
www.one80digitalpost.com.au
Old 02-07-2005, 12:56 PM
DigiTechSupt's Avatar
Audition paths need to be assigned to outputs 1-8. Outputs 9-16 will not pass audio.
regards,
Digidesign Technical Support
Avid Audio Tech Support
Support FAQ
"you need to have a valid audition path in I/O setups to audition" - HELP ! Riquier Pro Tools M-Powered (Mac) 5 04-29-2014 02:34 PM
Never had these problems with Logic or Audition ... ptfigg macOS 3 08-15-2013 08:05 AM
Audition 1.5 and Mbox 2 zamboknee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-28-2006 01:35 PM
Problems with M-Box and Adobe Audition frankreverbo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-02-2005 11:41 AM
Audition problems in Import Dialog Box? anders Pro Tools TDM Systems (Mac) 0 11-30-2005 08:15 PM
