Midi to USB adapter
I'm using an M-Audio Keyrig 49 as my USB controller to do pianos and virtual instruments.
But I'm curious if I can use my 88-key Casio Privia keyboard, with real piano action, and use the midi-out on the side, with a USB adapter, that would allow me to go into my Imac using the USB port, as I do with my Keyrig 49, and use the Casio instead of the Keyrig. I'm just not sure the steps I would need to go through. And how would I get Pro Tools to recognize it? Would I need to install drivers or anything complicated like that? |
Re: Midi to USB adapter
You can definitely do this. The M-Audio Uno is a good choice. It will work the same way as your Keyrig, in that it should be automatically recognized on the Mac. If not, go under Utilities>Audio Midi Setup, and click "Rescan Devices" and it should be recognized.
Alternatively, you could also look into a keyboard controller that also functions as a Midi to USB interface, such as any of the Axiom series (including the 1st generation ones, if you find one used). |
+1 on the M-Audio Uno
I use one, have used it on dozens of systems too with no problems.
MacBook Pro 2.2 GHz Core i7 4GB RAM 10.8.5, PT 10.3.4, Waves v9.1, Duet 2 redtuxedo.com milkmoneyconsulting.com mindexpansiontechnology.com |
VST to RTAS Adapter: Usable on non-MIDI tracks? | Kryst | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-15-2006 03:53 PM |
ADC to VGA adapter | iamspooky | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-07-2002 12:00 AM |
What midi adapter to buy? | Voideco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-22-2001 10:18 AM |
Midi "Y" Adapter? | trackfive | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-04-2001 03:13 PM |
Keyspan USB Serial Adapter & Midi Timepiece Av | O.D. | Pro Tools TDM Systems (Mac) | 0 | 11-14-1999 11:28 PM |
