Old 11-09-2007, 05:06 PM
Siegfried Meier Siegfried Meier is offline
Default Crash then Freeze
Ever since purchasing our new HD3 rig last Feb, I've been plagued with this strange bug. Pro Tools will suddenly crash, then if I try to launch it again, the entire computer freezes up. If I restart the computer first, then it's fine, but if I don't, complete lock of the OS. This has been since 7.3 and is still there in the newest version. Anyone else experiencing this? Or am I doomed to always have to restart after it crashes? Using a dual 2.66 Intel Mac.
Thanks,
Siegfried
Old 11-10-2007, 02:58 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Crash then Freeze
Thanks,
Siegfried
First thing !! always re-boot after a crash
Second thing!! this is not a bug
This is a problem with your rig only and can probably be sorted with a bit of effort :
Do you get a crash report when it quits? they are stored in Mach HD / User / your name / library / prefs / logs / crash reporter
You need to look at the crash log and see which thread has caused the quit and see if it names any culprits! or paste the crash log here for others to view.
I assume you have done all the troubleshooting tips as described in the troubleshooting thread?
Especially a fresh install if Pro Tools!! don't panic, this will only take 5 minutes and is the best thing to do if you are getting constant quits.
The second major cause of these problems is hardware; ram / hard drive / USB device/ hub etc.
When you have exhausted all the software avenues! as suggested above! then start with your hardware checking.
Chris
Producer, Engineer,
www.ukmastering.com
Freeze and crash every 5-10 minutes SBMusicAndPost 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-29-2010 06:35 PM
plug-in freeze, crash... HELP jasonforman Pro Tools M-Powered (Mac) 3 12-11-2009 05:36 PM
Crash/freeze qwerty007 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-07-2007 02:06 PM
Please help! Odd freeze/crash sHERB Pro Tools TDM Systems (Mac) 0 02-05-2007 02:04 PM
freeze and crash Julien J. Noel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-26-2001 07:50 PM
