Old 10-04-2006, 02:58 PM
soundguydave soundguydave is offline
Default Perserve Folder Hierarchy?
What exactly does this option do in 7.2 under save session as?
Dave Kaduk
Particle Audio
Old 10-04-2006, 06:21 PM
jimlongo's Avatar
jimlongo jimlongo is offline
Default Re: Perserve Folder Hierarchy?
If you have audio which you have had to split across multiple drives/folders, this Saves the session with audio in folders named for the drives/folders where the original audio was stored.
For instance, I have a 96 track session. I have to split it across 4 firewire drives (Drive_A, Drive_B, Drive_C, Drive_D) for mixing. When I do a Save Session Copy (preserving heirarchy) I get a backup that has audio in 4 folders (called Drive_A, Drive_B, Drive_C, Drive_D). So I can archive the session and if I need to remix I can easily restore the audio to multiple drives. Saves a lot of work that gets ruined by a normal Save Session Copy.
Hope that wasn't too confusing.
noise | jimlongo
Old 10-05-2006, 11:15 AM
That rules. Too bad I oonly work on one drive. Sounds like a cool feature
Thanks!
Dave Kaduk
Particle Audio
Old 10-05-2006, 11:48 AM
KingTor KingTor is offline
Sounds like you should go out and buy more drives!
That is a cool feature. Simple, yet very cool.
Tor Kingdon, Chief Sound Guy
Hear Kitty Studiostwitterfacebook
Old 07-12-2021, 07:21 PM
noobstudioguy noobstudioguy is offline
Generally speaking, I should always check this box then. Better for organizational purposes.
Any downside to always checking this box?
Why is there a VSTPlugins folder under my Avid folder? EnjoyRC Windows 1 10-28-2011 11:55 AM
Why can't I set my plugins root settings folder outside PT's default folder? RiF Pro Tools 9 4 09-26-2011 12:11 PM
Plug-Ins Alias folder points to wrong folder??? nod25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-26-2009 03:43 PM
>> Hierarchy of Groups - not as it once was. Howardk Pro Tools TDM Systems (Mac) 4 10-05-2007 02:52 PM
Digidesign folder in OS X's Library Folder Armando 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-26-2001 08:00 PM
