Old 09-08-2021, 05:19 PM
lof_audio lof_audio is offline
Default Avid Dock - Protool 2018.12 - Eucon Firmware compatibility
Hey Everyone !
I'm running Protools 2018.12 on Imac Highsierra 10.13.6,
I'm using the Avid dock 1.1.18.0 Frimware, everything is fine until my AvidControl App on my Ipad updateded to 2021.6.1.94, and then Protools was not able to connect to the App, so Since I couldn't Downgrade the app on the Ipad, I Updated the EuControl to the Last version. Nothing works, I tried some older versions. Nothing worked, so I just end up on the 4.7.4.10 version.
So, the Avidcontrol Mismatched with the Eucontrol, and the Dock became unavailable on the Eucontrol, and Protools cannot link with them.
So,
Is it possible to get the older AvidControl on the Ipad in order to fix the problem ?
or
Is there any compatibility with the new AvidControl 2021.6.1.94 and protools 2018.12 ?
and
If I upgrade the firmware of the Dock to the latest version and the Eucontrol latest version to match with the new AvidControl 2021.6.1.94, is there any compatibility with the Protools 2018.12 ?
is There any solution ?
Thank you so much for taking the time !
Eucon 3.2.2 installer error + firmware downwards compatible with eucon 3.1 deauditievedienst Artist Series 2 07-14-2021 09:33 AM
S3 as EUCON (with Dock) and AVB Interface ViciousLullabyz Avid S1, S3, Dock and Control App 4 06-21-2020 04:25 PM
Eucon/S3/Dock/Avid Control delay in responding feakerboo Avid S1, S3, Dock and Control App 1 04-23-2020 06:43 PM
Dock Monitor control 2018.7 eucon master fader Jamie Mac Avid S1, S3, Dock and Control App 5 08-02-2018 07:31 PM
Pro Tools Dock for 2018, or Artist Mix? TNM Pro Tools 2018 15 02-21-2018 05:19 PM
