Getting audio from Dropbox to Protools?
Just wondering how to get audio files from Dropbox to Protools, thanks.
Macbook Pro OS X Yosemite 10.10.4 / 2.5GHz / IC i7 / 16 GB 1600 MHz DDR3 / Startup Disk Macintosh HD Protools 12 LE |
Re: Getting audio from Dropbox to Protools?
if its a link from someone else just download the file then either use the import audio command or menu option or drag into pro tools from the finder.
if its from a drop box folder on your hard drive I think you can also just drag and drop into pro tools from the finder. otherwise try searching "import audio" in the pro tools reference guide
Jay-J System MacPro 12 Core • 24 G Ram • 10.12.6 PT 12.8.1 • Mbox 3 Pro • Plug-ins Verified 4 HD • OS ssd | Audio ssd | Sample Library ssd | Storage MAXPower eSATA 6G Card • Wiebetech RTX100H-Q Kensington Trackball Works/Orbit Optical Bluetooth off/Airport on and off. |
Save file to local computer
in pro tools - import audio to a session
That^^^ unless its zipped(or otherwise compressed) in which case, you simply need to EXTRACT the zipped file first, then use the IMPORT AUDIO command in your PT session
In my experience Pro Tools often has trouble seeing files in your local dropbox fyi. Sometimes it takes hours for the files to show up in the import audio window even though they are present in the dropbox. Best to copy the files to your session drive and then import or drag and drop as long as you have it set to copy imported files. Running sessions from your dropbox can also wreak havoc on a session and render it un-savable or cause other errors.
I do this a lot. Download from Dropbox to a folder on your local HD. If the file is zipped, you need to unzip it. Usually, I go to my PT Session drive, find the session folder, and make a special folder there for any downloaded audio from an outside source. Put your downloaded files in that folder. Open the PT session, use Import Audio and find the folder you just put the audio files in and import them to your session. Make sure the sample rates match!
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
If it's a session I will move it to my audio drive. If it's just wavs I'm importing into an existing session, I usually import it directly from dropbox. Just make sure you have PT setup to copy all files to the session folder. Been using dropbox daily for several years now, with zero issues.
2022.12, OS 13, M1Max, 64gig of ram, Samsung t7 and T5 external drives, Apollo 16mkII, Apollo Twin MkII |
11.3.2 Dropbox suggestion | JChance | Pro Tools 11 | 7 | 10-04-2015 04:12 AM |
Quicktime Bounce No Audio once uploaded to Dropbox | Intransit | Pro Tools 11 | 2 | 05-28-2014 12:10 PM |
Need Help with Dropbox File sharing | SbrickwallS | macOS | 1 | 08-18-2011 10:27 AM |
Dropbox transfers? | Tom Case | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-16-2010 06:20 PM |
