Old 06-26-2013, 07:52 PM
rgalpin rgalpin is offline
Default Sync Issue Digi002 ProTools LE 8.0.3
Digi002 ProTools LE 8.0.3 on Windows XP
my system is recording stuff behind the beat. when using a microphone and recording the metronome the waveform should show blips right on the beats - but... not.
Any ideas?
Old 06-26-2013, 08:33 PM
Top Jimmy's Avatar
Default Re: Sync Issue Digi002 ProTools LE 8.0.3
Wasn't this a driver problem on 8.0.3 LE? Update to 8.0.5 and the last V8 driver. I was on 8.0.5 for a while and it was the best of all the versions of 8.
Buttdialed by me & Tapatalk
James Cadwallader
Old 06-26-2013, 08:51 PM
Craig F Craig F is offline
I can't tell how far it's off from the pic
input latency would be my first guess but it looks a bit big for that
Thank you,
Craig
Old 06-27-2013, 08:18 AM
cool. thanks - i will try 8.0.5
will the 8.0.5 update include the latest v8 driver?
Old 06-27-2013, 10:32 AM
Top Jimmy's Avatar
Download and use the 9.0.2.65 driver for the 002. It was released the day before the 8.0.5 update was released.
http://avid.force.com/pkb/articles/e...&x=-1195&y=-20
James Cadwallader
Old 06-27-2013, 09:30 PM
updated to 8.0.5
updated the driver to 9.0.2.65
still saw a delay when recording the metronome.
but I think i found a solution. i set the Global MIDI Playback Offset to -1000 samples and now it seems to line up perfectly. i don't know if there will be any undesirable fallout from this adjustment but it sure made the the MIDI track and the audio recorded line up better.
any further insights on this would be welcome!
Old 06-28-2013, 03:25 AM
To get the best answer, we need all the little details "Recording stuff" is way too ambiguous. "sending midi to an external sound device, and recording audio from that"...paints a much clearer picture(and setting the proper midi offset is exactly the right procedure to do)
Old 06-28-2013, 05:29 AM
found my problem... monitor latency caused by a certain plugin i was using on the master track and subs. MAXIM compressor. it was creating a 50ms delay. replaced it with another compressor and all is well. i had to set the Global MIDI Playback Offset back to 0.
thanks for your help.
Protools 10 and DIGI002 issue. ilegal31 macOS 29 01-08-2013 01:47 PM
Protools 10 and DIGI002 issue. ilegal31 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-22-2012 05:50 AM
Midi Timing Delay Sync Issue: MTC Sync daysean 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 01-22-2007 11:48 AM
sync digi002 and mpc2000xl mn412 MIDI 1 11-06-2003 09:16 AM
how to sync digi002 and video? loitschix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 02-15-2003 01:59 AM
