Old 03-19-2021, 10:54 AM
adamino adamino is offline
Default Eleven Rack 96Khz
I want to set my eleven rack at 96khz and keep it that way yet every time I restart it defaults to 4100KHZ.
This is ridiculous that I can only set it at 96Khz through the driver app only.
I think that although this has been discontinued the least Avid could do is ceate a patch for this.
Old 03-19-2021, 11:14 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: Eleven Rack 96Khz
Are you on Windows? It could be you need to set it under Control Panel, Sounds. Set the sample rate on the playback and record tabs.
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 03-19-2021, 01:40 PM
Windows setups should always set sound properties to use the on-board sound card as the "default playback device". That way, Pro Tools can have exclusive control over all settings of the interface
Old 03-19-2021, 02:47 PM
yes i can set it to 98khz on the driver app in windows however, i use
it with a power amp into my cab and want the sample rate to remain at 98khz as it sounds better then 44100 khz.I am not using it as an audio interface.
Old 03-19-2021, 03:38 PM
jeffro's Avatar
jeffro jeffro is offline
On your ER... press and hold EDIT/BACK, scroll to Digital Clock/Input, press SW 1, set CLOCK SOURCE to Int 96 kHz, press EDIT/BACK 2x.
linkedin
Old 03-20-2021, 03:51 AM
Thank you all for your very kind assistance.
Old 03-31-2021, 04:43 AM
DonaldR DonaldR is offline
Never thought of changing the clock rate to 96K, will try.
Thanks for the tip.
Check out the Eleven Rack Presets Matched for Eleven plugins by Pro Tools Expert! Justin1524 Eleven Rack 0 11-27-2015 02:53 PM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 06:07 PM
How to send 96khz audio to Digi 002 Rack via ADAT saVas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-26-2004 10:25 PM
Logic with 002 rack. Can't use 96Khz AM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-02-2003 04:01 AM
