#21
Re: Post fader inserts.
So just to be clear the only thing you'd want a post-fader insert for is saturation? In that case, maybe the option to replace HEAT with another saturation plug-in would be better? I can't see any other type of processing working after the fader. Delay and other effects would make no sense. A compressor, maybe, but then you'd need *another* fader after it to control the level in the mix. So not really. A limiter? Makes no sense to me either really.
#22
Nope I have other reasons. But I have outboard summing so I give each channel its own color and work from there. It gives me a real console feeling. I have a dcommand and unfortunately channel strip plugins come with there own fader which the daw doesn’t control and it STINKS. Well back to mixing I go. Thanks for those who understand but don’t knock it until you try it. Sent from my iPhone using Tapatalk
WENT FROM HD TO M-POWERED
#23
I am not advocating for this and haven't used it , but if post fader plugs are useless, what case does that make for post fader sends?
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
#24
Edit : maybe I'm misunderstanding you and you mean a post-fader send after the post-fader-insert. A "post-fader-insert-send". That to me is just another example of why a post-fader-insert can't work. What would happen to the post-fader sends? They get ignored, presumably? And then you get signals sent to the saturation from the mix bus, but not to the e.g. delay? Man it's just making my brain hurt. |
#25
Post Fader INSERT. Not send.
#26
Listen to Rich.
Trim/gain plugin puts a fader wherever you want.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
#27
deleted
Volume fader vs post send fader - same scale? | Vitopower | Pro Tools 2019 | 5 | 07-09-2020 06:11 PM |
Feature request -post fader inserts on tracks/aux | Sonsey | Post - Surround - Video | 15 | 07-13-2018 08:22 PM |
*BUG* Pre-fader sends revert to post-fader upon session restart | Nico Breeze | Pro Tools 11 | 7 | 07-11-2014 10:47 PM |
DIGI: Will it ever be possible to implement Pre-Fader Inserts on the Master Fader? | Ricky Cobble | Pro Tools TDM Systems (Mac) | 5 | 05-05-2003 04:47 AM |
Master inserts are post-fader? Was: L1+ on Master = clipping | s2n | Pro Tools TDM Systems (Mac) | 10 | 11-20-2001 07:41 AM |
