PT2019.12 CPU Issue
i have a macbook pro 16" best processor... catalina newest version. from one day to the next the cpu issue returned....it looks like it is not protools. even without any active plg-in playback stops..... processor is on 2% in protools..... any ideas where i could locate the issue?
Re: PT2019.12 CPU Issue
Depending on the OS wouldn’t Task Manager or Activity Monitor tell you where you have 2% CPU activity if it isn’t ProTools causing it. And also if PT isn’t causing this CPU issue why are you posting here for help?
Occasionally here even when the cpu is like 2%, it freezes up for a few seconds then spikes all cores to 100% red and then overload.. is this what is happening to you too?
- Apple Mac Studio M2 Ultra/64gb/UA Apollo x 3+Adat x 3/UAD Satellite x 3/OS 14.41/PT 2024.3/Nuendo 13/LogicX |
About 3/4 times a day, the whole computer will freeze for about 4 seconds when I do one of the following things (which you think would all be completely benign): -Naming a track -Clicking on an insert box so that I insert a plugin. -Selecting a dropdown menu at the top of the screen... for example, just clicking on Audiosuite Playback will stop, the screen will freeze, and if I have the System Usage window open, once the computer becomes responsive again, the CPU usage will spike hard briefly. Who knew that it takes all the cores of an i9 to name a track? hahaha I've now taken up the habit of when I open a session, I'll click a dropdown menu, double-click on a track name, and click on an insert box. This seems to clear up any issues, if there are any, and then it's smooth going until I open up the next session. |
Finally - going to PT2019.x | musicman691 | Pro Tools 2019 | 8 | 08-02-2019 01:15 PM |
Will my rig run PT2019? | Steve Garman | Pro Tools 2019 | 4 | 05-28-2019 11:27 PM |
PT2019 and Alt | babaorum | Pro Tools 2018 | 4 | 05-20-2019 11:01 AM |
PT2019.5 and Win10 | senghor | Pro Tools 2019 | 2 | 05-11-2019 08:50 AM |
