BombFactory Pultec Bundle
I'm having massive CPU resources being taken up by the EQP-1A.
I instantiated 8 instances on stereo tracks. My CPU usage went from 1% to 79%. It eventually starts to fall to around 30% with fluctuations. Hmmmm.... I like these plugs. Been using them since they were on MAS in Digital Performer. Tried all the usual troubleshooting stuff. I had been wondering why my setup was so bogged down lately. I'd started using the BombFactory stuff again as opposed to some other things. Any ideas? Thanks.
Pro Tools 10.3.9, MBP 2.4GHz Intel Core 2 Duo OS 10.6.8 4GB/Ram, 7200RPM 750GB Internal HD, Focusrite Saffire Pro 40, Digidesign Mbox 2. It is what it is... ScrewMakerMusic |
Re: BombFactory Pultec Bundle
I'm bumping this, as this problem is bumming me out. Still happening...
Hmmmmmmmm..... I tried the usual troubleshooting stuff per DIGI posts etc. This problem seems to have started happening since going to PT8. No other problems seem to have crept up. Thanks.
Man, I don't know what's going on but you could just use the Audiosuite version. Once you find the setting in RTAS, just save it as a preset and call it up Audiosuite and process the track and remove the insert. Meanwhile, what are you doing with it that you use so many. What I'm getting at is; say you put it on several things to boost high end, maybe your monitors are too dark? Or if you add the same treatment to a bunch of BGV tracks, maybe just bus them all to a stereo aux in insert a single instance of the EQ?
albee1952,
I was thinking that I might be using a lot too. LOL. I generally setup my dummy sessions with about 8 Instrument, Stereo and Mono Audio tracks and instantiate EQP-1A and BF-2A on each track. It only seems to have gotten flaky in PT8. Or my mind may be going !!! LOL. Previously I was using McDSP AC1, E4 and ML1000 (or CB4). So I have loaded PT8 with a lot of plugins. It just seems the EQP-1A is being difficult. Hmmmmmm...... Thanks for your help.
Well...
I just pulled out a bunch of manuals (PDFs) and compared the DSP usages on HD Accel cards for the EQP-1A, McDSP stuff, EQIII and Dynamics III, etc. (I'm running PTLE but I thought that the usage charts on the HD Accel cards may be useful for comparisons.) It appears that the BombFactory EQP-1A is a resource hog from hell !!! LOL. Can anybody else confirm that the EQP-1A is a resource hog on their machines? I'd appreciate the help. Thanks.
More observations...
I opened a session with no VIs. It was quite happy as far as responsiveness. When I added VIs it bogged done immediately. So it may very well be a processing issue dependent on VIs. Damn !!! LOL. I was hoping to run all this together simultaneously. Maybe I need to move to an 8 Core.......... Thanks. Looking forward to anyone else's results !
Just Bounce all your VI's down to Audio and you should be good to go.
Stay true to the sound,Less is best |
If you can post a plug-in version list, I likely can point out which plug-ins may be causing problems.
Which Mac are you on? Have you tried reducing the number of processors dedicated to RTAS in the playback engine by 1 less than the maximum available? |
Thank you DIGI.
Running one processor (as opposed to two) usually works really well until EQP-1A is instantiated (Damn. LOL.). Even with VIs. (I often run it this way as I sometimes use MainStage as a guitar processor, etc. on the same machine, for inputs into PT.) Here's my Mac info: Mac Book Pro 2.4GHz Intel Core 2 Duo OS 10.5.6 4GB/Ram Here's the list generated from the Tech Support Utility: ------ Fri Mar 6 17:42:16 CST 2009 Pro Tools Version __________________________________________ Pro Tools LE.app 8.0.0cs2, Copyright 1991-2009 Digidesign, A Division of Avid Technology, Inc. Pro Tools M-Powered.app 8.0.0cs2, Copyright 1991-2009 Digidesign, A Division of Avid Technology, Inc. Plug-In Versions __________________________________________ AIRChorus.dpm 1.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. AIRDistortion.dpm 1.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. AIRDynamicDelay.dpm 1.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. AIREnhancer.dpm 1.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. AIREnsemble.dpm 1.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. AIRFilterGate.dpm 1.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. AIRFlanger.dpm 1.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. AIRFrequencyShifter.dpm 1.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. AIRFuzz-Wah.dpm 1.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. AIRKillEQ.dpm 1.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. AIRLo-Fi.dpm 1.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. AIRMulti-Chorus.dpm 1.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. AIRMulti-Delay.dpm 1.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. AIRNon-linearReverb.dpm 1.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. AIRPhaser.dpm 1.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. AIRReverb.dpm 1.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. AIRSpringReverb.dpm 1.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. AIRStereoWidth.dpm 1.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. AIRTalkbox.dpm 1.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. AIRVintageFilter.dpm 1.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. AmpegSVXUNO.dpm Ampeg SVX UNO 1.1.1, Copyright 2005 - 2007 IK Multimedia AmpliTube1.xLE.dpm AmpliTube 1.x LE, (R)(C) IK Multimedia 2006 AmpliTube2DUO.dpm AmpliTube 2 DUO 2.1.2, Copyright 2002 - 2007 IK Multimedia Audio Ease BF Essential Clip Remover.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. BF Essential Corr.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. BF Essential Meter.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. BF Essential Noise.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. BF Essential Tuner.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. BFD LITE RTAS OSX BFD Lite.dpm BFD Lite version 1.5.48.5, Copyright 2003-2008 FXpansion Audio UK Ltd. BitterSweetII.dpm 1.4.0.0, Copyright 1991-2008 Flux:: Sound and picture developement Boom.dpm 1.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. Broadband Noise Reduction LE.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Chorus.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Click.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Cosmonaut Voice.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. D-Verb.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. DB-33.dpm 1.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. DE555_HD.dpm 1.0x18, Copyright 1998-2007 McDowell Signal Processing, LLC DigiReWire.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Dither.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Dynamics II.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Dynamics III.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. EQ II.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. EQ III.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Elastic Audio.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Elastik.dpm Version 1.5.2.3 Copyright 2004-2006 Ueberschall Eleven Free.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Eleven LE.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Fairchild 660.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Fairchild 670.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Flanger.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Focusrite d2.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Focusrite d3.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Frohmage_RTASMachO.dpm Copyright © Ohm Force 2000-2008. Funk Logic Masterer.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. FutzBox_HD.dpm 1.0x18, Copyright 1998-2007 McDowell Signal Processing, LLC Hybrid Hybrid.dpm 1.5.2.7597 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. Invert-Duplicate.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. JOEMEEK Compressor.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. JOEMEEK Meequalizer.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. KontaktPlayer2.dpm 2.2.4, Copyright © 2007 Native Instruments Kore Player.dpm 2.0.4, Copyright © 2008, 2008 Native Instruments L2007 Mastering Limiter Demo.dpm "1.3.3d, Copyright (c)2006-2007 Steven M. Massey, All Rights Reserved." LiquidInstrument.dpm Version 1.5.1.2 Copyright 2004-2006 Ueberschall LoFi.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. MDW_EQ_3B_LE.dpm 2.2.0r10, Copyright 2006-2007 Massenburg Design Works. MDW_EQ_5B_LE.dpm 2.2.0r10, Copyright 2006-2007 Massenburg Design Works. MOTU Ethno Instrument.dpm 1.0.1, Copyright © 2006 MOTU MOTU Symphonic Instrument.dpm 1.1.3, Copyright © 2006 MOTU MOTUAudioFeeder.dpm 1.0x0, Copyright 2006, Mark of the Unicorn, Inc. MX4 RTAS MX4 RTAS.dpm 2.2, Copyright © 2004-2008 MOTU. Massey CT4.dpm 1.1.0d, Copyright 2006 Steven M. Massey, All Rights Reserved. Massey DeEsser Demo.dpm 1.0.0 [1647] "Copyright (C)2008 Massey Plugins Inc., All Rights Reserved." Massey TD5 Demo.dpm 1.1.3 (1287) "Copyright (c) 2007 Massey Plugins Inc., All Rights Reserved." Maxim.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. MiniGrand.dpm 1.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. Mod Delay II.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Mod Delay.dpm 7.1.1, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc. Multi-Tap Delay.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. NF575_HD.dpm 1.0x18, Copyright 1998-2007 McDowell Signal Processing, LLC Nomad Factory Normalize-Gain.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Ping-Pong Delay.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Pluggo-RTAS.dpm Pluggo-RTAS, Copyright � 2006 Cycling '74 Pultec EQH-2.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Pultec EQP-1A.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Pultec MEQ-5.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Purple Audio MC77.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. RNDigital RectiFi.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Reverse-DC Removal.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. SFX Machine Pro RTAS.dpm SFX Machine Pro™ 1.1.2, © 2006-2008 The Sound Guy, Inc. STTool.dpm 1.4.0.0, Copyright 1991-2008 Flux:: Sound and picture developement SampleTank2.xSE.dpm SampleTank 2.5 SE, Copyright 2001 - 2007 IK Multimedia SansAmp PSA-1.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. SciFi.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Signal Generator.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. SignalTools.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Slightly Rude Compressor.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Smack! LE.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. SoundHack +binaural.dpm 12.4.0x0, Copyright 1991-2007 SoundHack. SoundHack +bubbler.dpm 6.0.6x0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. SoundHack +chebyshev.dpm 6.0.2x0, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc. SoundHack +compand.dpm 6.0.2x0, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc. SoundHack +decimate.dpm 6.0.2x0, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc. SoundHack +delay.dpm 6.0.6x0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. SoundHack +matrix.dpm 6.0.2x0, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc. SoundHack +morphfilter.dpm 12.4.0x0, Copyright 1991-2007 SoundHack. SoundHack +phasescope.dpm 6.0.2x0, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc. SoundHack +pitchdelay.dpm 6.0.6x0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. SoundHack +spectralcompand.dpm 12.4.0x0, Copyright 1991-2007 SoundHack. SoundHack +spectralgate.dpm 12.4.0x0, Copyright 1991-2007 SoundHack. SoundReplacer.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Strike.dpm 1.0.2.7527 Copyright 2008 Digidesign, A Division of Avid Technology, Inc. Structure.dpm 1.0.2.7584 Copyright 2008 Digidesign, A Division of Avid Technology, Inc. Synchronic.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. THC Demo.dpm "1.0.2d, Copyright (c)2006-2007 Steven M. Massey, All Rights Reserved." TL AutoPan.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. TL InTune.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. TL MasterMeter.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. TL Metro.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. TL Space Native.dpm 8.0.0, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc. TRackS1.xEQ.dpm T-RackS 1.x EQ, (R)(C) IK Multimedia 2006 TRackS3.dpm TRackS 3.0, Copyright 2008 IK Multimedia Tape-Head.dpm 1.3.0d, Copyright 2006 Steven M. Massey, All Rights Reserved. Tel-Ray Delay.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. The Forte Suite.dpm 1.8, Copyright Focusrite Audio Engineering Ltd Time Comp-Exp-Pitch Shift.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Time Shift.dpm 8.0.0, Copyright © 2005 by Digidesign, a division of Avid. All rights reserved. TimeAdjuster.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Transfuser.dpm 1.0.1.8705, Copyright 2008 Digidesign, A Division of Avid Technology, Inc. Trim.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. UVIWorkstationPT.dpm 1.0.14, Copyright 2009 Univers Sons Vacuum.dpm 1.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. VariFi.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Velvet.dpm 1.0.2.7467 Copyright 2008 Digidesign, A Division of Avid Technology, Inc. Vinyl.dpm 1.7.3, Copyright © 2006 iZotope, Inc. VocALignLE.dpm 2.9.6, Copyright 1995-2007 SynchroArts Ltd. Voce Chorus-Vibrato.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Voce Spin.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. X-Form.dpm 8.0.0, Copyright © 2005 by Digidesign, a division of Avid. All rights reserved. XPand!.dpm 2.0.0.8542 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. bombfactory BF-2A.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. bombfactory BF-3A.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. bombfactory BF76.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. moogerfooger AD.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. moogerfooger LP.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. moogerfooger Ph.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. moogerfooger RM.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. vt3.dpm 1.1.0d, Copyright 2006 Steven M. Massey, All Rights Reserved. Plug-Ins Unused Versions __________________________________________ Analog_Channel_HD.dpm 3.2x18, Copyright 1998-2007 McDowell Signal Processing, LLC Channel_G_HD.dpm 2.2x18, Copyright 1998-2007 McDowell Signal Processing, LLC Chrome_Tone_HD.dpm 2.2x18, Copyright 1998-2007 McDowell Signal Processing, LLC CompressorBank_HD.dpm 4.2x18, Copyright 1998-2007 McDowell Signal Processing, LLC FilterBank_HD.dpm 4.2x18, Copyright 1998-2007 McDowell Signal Processing, LLC MC2000_HD.dpm 3.2x18, Copyright 1998-2007 McDowell Signal Processing, LLC ML4000_HD.dpm 1.1x18, Copyright 1998-2007 McDowell Signal Processing, LLC Reel Tape Delay.dpm 7.4x0, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc. Reel Tape Flanger.dpm 7.4x0, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc. Reel Tape Saturation.dpm 7.4x0, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc. Revolver_Native.dpm 1.1x8, Copyright 1998-2006 McDowell Signal Processing, LLC Synth_One_HD.dpm 4.2x18, Copyright 1998-2007 McDowell Signal Processing, LLC WaveShell-DAE 6.0.5.dpm WaveShell-DAE 6.0.6.dpm Toolkits and Digitranslator Versions __________________________________________ Music Production Toolkit 8.0.0, Copyright © 2006 by Digidesign, a division of Avid. All rights reserved. DV Toolkit 2 8.0.0, Copyright © 2006 by Digidesign, a division of Avid. All rights reserved. Digitranslator 2 8.0.0, Copyright 1991-2005 Digidesign, A Division of Avid Technology, Inc. Digitranslator 1 is not installed Complete Production Toolkit is not installed
It appears that the BombFactory JoeMeek VC5 and SC2 have this problem also. Damn ! LOL.
Bombfactory pultec Plug In scratches | Digiyama | VENUE Live Sound Systems | 1 | 12-04-2007 04:43 PM |
Pultec Bundle | 1tonstudio | ProControl, Control|24, Command|8 | 5 | 12-11-2004 03:55 PM |
pultec bundle | shaun1234 | Pro Tools TDM Systems (Mac) | 5 | 08-29-2004 12:14 PM |
Pultec Bundle | BinkBonk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-24-2004 10:02 AM |
How to oprate the Bombfactory Pultec EQ? | Ben Jenssen | Tips & Tricks | 6 | 04-25-2001 07:38 AM |
