Old 09-22-2007, 10:46 PM
Robbie Hollywood Robbie Hollywood is offline
Default Volume Automation
I automated my volume with some fades here and there. Now I want to move the whole track down a few dB. How do I do this without going through and moving down each individual automation inflection point? How can I move the entire track volume down at once??
Pro-Tools M-Powered 7.4.2
Apple iMac 2.16 GHz Intel Core 2 Duo, 2GB
ProjectMix I/O
Old 09-22-2007, 11:38 PM
Default Re: Volume Automation
Use the Selector tool and double click the track then pull down the automation with the Trim tool.
filosofem
Aaron Mulqueen - 001 HD Native
Old 09-23-2007, 05:14 AM
GTBannah GTBannah is offline
filosofem
Will it work if you click the fader in the mix window? Not near the system now.
Derrkins
GuyBarTola
PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!!
Old 09-23-2007, 05:36 AM
musicalavtech musicalavtech is offline
Another way is to click and drag just after the last break point, and it will move the whole track's automation up or down. Either way works nice.
OSX10.6.8, 1st gen Power Mac,
PT8.0.5, Mbox2
Old 09-23-2007, 08:07 PM
Yes, good tip musicalavtech, I keep forgetting about that one.
filosofem
Old 09-23-2007, 08:10 PM
Nope. Not with Breakpoints on the playlist.
filosofem
Old 09-24-2007, 03:20 PM
You could also use a gain plugin or lower the output level on an EQ plugin if you have any on that track.
Volume Automation.. thierryhenry Pro Tools 10 5 01-05-2013 12:46 PM
Converting Volume Automation to Clip Gain = Higher Volume! EricWillhelm Pro Tools 10 8 11-01-2011 11:12 AM
FCP, OMF & volume automation idris Post - Surround - Video 9 09-03-2010 08:06 AM
volume automation cpt Pro Tools TDM Systems (Mac) 9 02-12-2010 01:30 PM
Volume Automation Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 11-10-2003 02:23 PM
