Old 07-30-2006, 01:59 PM
farside farside is offline
Default Whos using a UAD-1?
Anyone using a UAD-1 with LE? ...pros/cons? ...latency?
I'm currently on 6.4
Old 07-31-2006, 04:56 AM
therecordinghouse therecordinghouse is offline
Default Re: Whos using a UAD-1?
i am, i love it! the pros are youget excellent plugins. the 1176ln just blows the BF76 out of the water. i have had my uad-1 for 2 years, just recently got PT le. i was used to the 1176ln, the bf76 just sounds muddy to me.
pros
EXCELLENT plugins
1176ln
la2a
plate 140
i hear the new neve is killer too!
cons
latency (no PDC via PT)
however, universal audio supplies a delay comp plugin that works flawlessly, only downside is it eats up an insert on ever channel that does NOT have a uad-1 plugin on it.
Lynn Graber
Studio and Mobile Recording, Fort Wayne, IN.
Old 07-31-2006, 05:49 AM
Phil Jeffers Phil Jeffers is offline
Hi, I've just bought one... heard they're the best around. I'll give you a UA vs. Waves report soon! Think latency would be the same...
Old 07-31-2006, 09:08 AM
chanlon25 chanlon25 is offline
I own a UAD and love it. I will say that my life has GREATLY improved with the following setup:
Mac OSX.4.6; G5 2x2.0/ 5.5GB Ram
PT 7.1cs9
FxPansion VST-RTAS Wrapper 2.0
UAD Software v4.3
I was very frustrated with my UAD setup in PT6.9 with VST FxPansion 1.7 - the performance was horrible, and I crashed a LOT (mostly -6086 errors). Now that I've upgraded to the latest versions of PT, FxPansion, Max OSX, etc I have noticed an amazing difference in performance. No more crashes, glitches, and much faster performance overall between the UAD and PT.
Also - because of the ADC issue, it's necessary to have the 16 extra busses that PT 7 provides.
The UAD plugs really sound wonderful!
My $.02,
C
Old 08-14-2006, 07:48 AM
Bezo Bezo is offline
Extra 16 buses? Was that with one of the updates, expansions...?
PTLE 8.0.5, Digi 002 Rack
iMac 3.06Hz Intel Core 2 Duo w/8GB RAM, OS 10.6.8
Glyph GT050Q Drives
Old 08-16-2006, 04:59 AM
The Dubnicks The Dubnicks is offline
I got a flexi pack last week and have used it in both Pro Tools LE and DP (which has delay compensation). It's great - the only PT specific downside is PT LE's lack of APDC, but the high number of busses make it workable and the UAD Delay Compensation plugs don't seem to be much of a hit on the CPU of the card or the computer. Aside from that, the only bummer is that all the plugs are so nice, that it makes it hard to decide - definitely pick up the flexi pack if you can. I know I'll get some crap for this, but I think I've just used the BF1176 for so long that, for ultra aggressive drum use, I still kind of prefer it to the UAD 1176s for that squeezing the ring and decay out of the drums, but that might just be my bad taste - hahahah. The LA2A and Fairchild are unbelievably cool.
PT 10 and Logic 9.1.6
OSX10.6.8
Mostly Focusrite Saffire, sometimes Digi 002R
Old 08-16-2006, 07:13 AM
ladewd ladewd is offline
I have 3 cards in my aging single 1.25gHz G4. I love these plugins, and they really help out with the underpowered G4. The latency is a pain, but with 3 cards, I usually just put a EX-1 on each channel. That way I don't have to worry about latency, and can substitute an LA2A or other plugin when the channel strip isn't cutting it. 99% of the time, the channel strips seem to meet my needs and sound rather good.
CA
Mac Pro 5.1 12Core 48GB RAM, 4 Internal Drives Mackie Onyx 1640i, PTLE 12.7 w/MPTK2, OSX Yosemite. MacBookPro 13" 2.26GHz 8GB RAM, OSX El Capitan w/MOTU Ultralite Mk3.
Old 08-17-2006, 03:01 AM
nortonmanx nortonmanx is offline
i'm having a lot of trouble with my UAD-1 ultra pak. i get an error message saying:
"DAE ran out of time while sending audio over the PCI buss. Try reducing number of tracks, or using a playback engine with fewer voices per DSP. (-6042)"
as soon as i try to use any of the UA plugs. it plays for a second or so and then crashes.
this is very frustrating. does anyone have any experience in this? i have G4 500mhz, 1G ram, PT 6.4 and digi 001. i know it's an old setup put according to UA it should qualify...
cheers,
segu
Old 08-17-2006, 08:26 AM
Bezo - I believe that PT7 has increased busses from 16 to 32; go into your I/O window and you can assign the extra 16 busses.
Old 08-17-2006, 10:37 AM
got it working. changed places with the UAD-1 card which was on slot two and the 001 which was on slot three... after that all systems go! thanks to excellent customer service from UAD. and thanks to fxpansion too, cheerio, segu
So...Whos excited about That Big Refund!!! Ill Soul Productions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 31 02-11-2010 11:06 AM
Kentsfield... whos got one... does it work ? Bob Legs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-21-2006 04:37 PM
Whos The King Of The DUC ?? icouldntbeleiveit General Discussion 46 10-15-2004 10:13 PM
I find Digis Faults Unacceptable whos with me? mxsoul 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 36 10-20-2003 07:03 PM
Low-end systems...come on...whos got the worst computer here? Dr.John 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 38 01-07-2002 12:59 AM
