Digi? will C24 ever work again+preset window open?
Ever since 6.7 upgrade, the control 24 goes offline when a plugin presets window is open! This is a real pain in the A S Not being able to even stop/start the session! and especially not being able to bypass or adjust during playback. It used to work must be fixable Chris
Re: Digi? will C24 ever work again+preset window o
bump
Is this still an issue? Have you been able to work it out, yet? |
PT LE 8 BUG: Shortkey doesn't work when a plugin window is open | ugosound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-24-2009 11:09 AM |
Command 8 unavailable when preset dialogue open!!? | crizdee | ProControl, Control|24, Command|8 | 0 | 04-21-2005 08:36 AM |
The Protools Plugin Preset Co-op is open! | tld | General Discussion | 11 | 09-25-2000 09:16 AM |
The Protools Plugin Preset Co-op is open! | tld | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-22-2000 09:08 AM |
The Protools Plugin Preset Co-op is open! | tld | Tips & Tricks | 0 | 09-22-2000 09:07 AM |
