#51
Re: Mic Preamps....PLEASE HELP!!!!!
-Duardo |
#52
I was also uncertain about which pre to get for m system, so I decided to get 3D PRE AUDIO from sweetwater, I made up my mind...
#53
i think the point luv is (or should be) tryin' to make isn't that the budget stuff sounds the same from one piece to the next, rather that though the elephant may indeed drop a bigger load than the turtle, in the end, they're still both feces.
ml |
#54
Yaicks!!! [img]images/icons/shocked.gif[/img] Go write a song or something. [img]images/icons/grin.gif[/img]
Take Care, Gabriel. |
#55
Hey Duardo,
Tell us how the TAMPA harmonic "adjustments" sound. They say that that valve preamps "warm up" the mids but TAMPA does the "Valve thing" to the whole spectrum. Is this the case and is it audible. Do your ears like it or is it just a label on another preamp box? I look forward to your reply. Mark |
#56
I hear that the new Summit Audio half-rack mic pre's and compressors are awesome and about $500.
The engineer I mostly work with uses Vintech recreations of the Neve pre-amps which are about $1200 and are phenomenal. Do a google search for Vintech. but on a budget, i'd go for the summit audio stuff 'cause their top end stuff is great and it's essentially the same stuff but scaled down to try and make some more $$. t. |
#57
Thought I might chime in here and give an opinion.
I am using an Amek 9098 DMA into an Apogee Rosetta into Digi 001 via SPDIF and it sounds amazing. Smooth....open highs. Detail for days. No noise to speak of. Really and exceptional pre / AD combo. As with anything audio....YMMV depending on the source.....but I have no problems recommending this setup to anyone who wants an outstanding front end. Best of luck |
M-Audio 410 preamps better/same/worse than Digi 001 preamps? | SixChurchStreet | Pro Tools M-Powered (Win) | 0 | 02-20-2008 12:08 PM |
003 preamps VS Focusrite voicemaster preamps? | TREBLEBLEED | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 07-28-2007 01:56 AM |
Looking for Mic Preamps to compliment 002 preamps | murr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 03-18-2004 06:48 AM |
Focusrite Preamps and Digi 002 Preamps ?? | rj333 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-01-2004 09:19 AM |
002 Mic Preamps vs. Mackie VLZ XDR Preamps | straynham | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 07-20-2002 05:41 PM |
