Old 05-03-2021, 04:39 AM
PhiltheGreek1 PhiltheGreek1 is offline
Default PT12HD software & summing amp
Hi
I’m using PTs 12.5 HD software (no HW) with Symphony Mk1 via USB running on a Mac 5,1 12 core.
I’m running the outputs to a summing amp and I often mult aux outputs to different outputs (either by + the same aux or duplicating) and monitor back in PTs.
I’m afraid I’m going crazy but I often notice phasey issues and my mixes fall apart. It happens with more plugins on but not an obscene amount - and the system usage is ok.
Are there any suggestions to check on things if this happens?
Does anyone else still use PThd 12 no HW and soundcard via USB?
It never felt stable to me I just don’t trust it.
The other pitfall I wasn’t aware of when not buying into HDX (for latency and security reasons), was that I lost side chain compensation - i used this a lot to blend and mix parts together on my old TDM system it worked great - but I was unaware for years that it wasn’t working after losing that system..
Cheers,
P.
Old 05-03-2021, 05:28 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: PT12HD software & summing amp
Hi, welcome to the community.
Phasing has nothing to do with how interface is connected. Try to find the culprit elsewhere.
Janne
Old 05-03-2021, 09:12 AM
Thank you for your welcome and advice.
I’m thinking a complete reinstall with no third party plugins and do some test mixes and go from there.
Old 05-03-2021, 09:26 AM
JFreak's Avatar
Good idea. Compatibility info here.
Janne
Old 05-03-2021, 09:47 AM
Thanks again :)
I want to ask, other than the obvious, like no 0 latency monitoring or differences in I/Os, no dsp powered plugins; what are people’s realistic experiences regarding the pitfalls of working on Pro Tools 12HD software no hardware.
I mean, the s/c delay comp issue came as a surprise and would have been enough to make me get the HDX card (when I could have afforded it). I’d love to know if there is anything else to be wary of.
Old 05-03-2021, 09:57 AM
JFreak's Avatar
Without Avid hardware you are limited to 32 i/o
Janne
Old 05-03-2021, 01:22 PM
One question, is EVERYTHING being routed thru the summing amp, or only some tracks? If its not all tracks, that's likely the issue
Old 05-04-2021, 03:45 AM
Hi
Thanks! haha yes everything goes through the summing or that would certainly be a phase problem
I duplicate/mult aux outs from PTs often - either by +outputs on the same or having 2 with identical plugs on - I feel the problem may lie here somewhere.
P.
Pt12hd spaceman Buy & Sell 4 12-09-2016 10:18 AM
Upgrade PT12HD mastertstudio Licensing & Accounts 2 03-03-2016 12:33 AM
Upgrading to PT12HD...now what YYR123 Pro Tools 12 4 09-19-2015 06:32 PM
pro tools summing or digital board summing kingz Pro Tools TDM Systems (Mac) 9 04-29-2004 12:46 AM
D8B Summing vs. Pro Tools Summing Sound Guy Andy Pro Tools TDM Systems (Mac) 10 03-08-2002 04:04 AM
