Old 04-03-2020, 04:33 PM
George Koreli George Koreli is offline
Default Using outboard gear (compressor) on master fader
Hi there,
Ive got an outboard compressor (elysia xpressor). The unit is hooked up correctly and works properly. When I put it on the master fader and bounce the track out I get a soundless mp3. Duration is correct but there is no sound.
For your info Ive tried exactly the same with a compression plug in and didn't have any problem with the mp3.
Any ideas why this is happening?
Thank you very much!
Old 04-22-2021, 08:13 AM
JMMPROD JMMPROD is offline
Default Re: Using outboard gear (compressor) on master fader
im having same issues, makes no sense in the pro audio world
Old 04-23-2021, 04:45 PM
Hmmm, maybe route everything thru an AUX track and let the AUX track feed the main outputs(and do the hardware insert on the AUX track). Or double-check the Bounce source. Maybe it got changed, or I remember some versions(not recent but back in the 12.x days) would pick random paths as the Bounce source(funny how the bounced file didn't sound so good when it was using my drum headphone mix bus).
BTW, advantage to routing thru an AUX on the way to the master: plugins on the master are Post-Fade(meaning a fadeout will not drive comps or limiters the same during the fade). Placing "master" dynamics on the AUX means they will be driven the same(because the fade happens AFTER any of those plugins)
Master Fader Limiter/Compressor SSL Compressor mesa3077boogie Pro Tools 9 8 07-11-2011 08:15 PM
MBOX and ext. compressor on the master fader? bryanbassett 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-12-2005 01:51 PM
Who mixes in the box, but uses an outboard comp on the master fader? bassmac Pro Tools TDM Systems (Mac) 5 04-22-2003 02:49 AM
Outboard Gear as Insert On Master Fader dmunach 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 01-14-2003 12:51 AM
Outboard S/PDIF Gear on the master fader!!! Pako Tips & Tricks 8 11-08-2001 11:49 AM
