Old 04-08-2015, 12:57 PM
CCash CCash is offline
Default QC software for Quicktime files?
We have to deliver Quicktime files of various codecs with picture and multiple audio stems baked-in (to be extracted later by someone downstream).
I'm starting to research a QC solution for our management/administrators; I'd like to find an easy, user-friendly software (or even hardware) solution that would simply play the files (without creating NEW media), allow them to turn tracks on or off as needed, and have meters or some sort of visual feedback for up to 8 tracks simultaneously.
QT Pro is what they're using right now... the last version that could go "Pro" was 7 but luckily it still runs on our Macs. You can turn tracks off as needed by unchecking them in the Movie Properties window. This works OK, but there's no visual feedback for tracks.
If you know of something please pass it on, and if I find anything decent I'll post it here.
Old 04-08-2015, 01:16 PM
StonehengeX StonehengeX is offline
Default Re: QC software for Quicktime files?
Try Switch by Telestream. The basic version is free and has an audio meters window which allows you to solo tracks/turn tracks on and off.
http://www.telestream.net/switch/overview.htm
-Stone
Old 04-08-2015, 01:28 PM
This looks promising... I'll check it out. Thanks!
Old 04-11-2015, 01:53 PM
nucelar's Avatar
nucelar nucelar is offline
Another simple solution would be mxf4mac player.
Old 04-11-2015, 10:17 PM
Thanks nucelar, appreciated. I'll take a look at this.
So far we're impressed with Switch. The only thing that's weird is it plays back stereo ProRes files as dual mono (panned center). Not great for non-technical people (they may not know the difference anyway, but why make things worse?). QuickTime Pro pans the same ProRes file left and right.
On the other hand, Switch does pan H264 stereo files, so it's not like it can't do it. Not a lot going on in the Prefs. Maybe the Pro version has some control over this.
HTML code is On
Software for converting Quicktime files Dolly Pro Tools TDM Systems (Mac) 6 06-08-2011 05:33 PM
Quicktime TC burn-in software s0und80y Post - Surround - Video 7 03-24-2009 05:53 AM
Is it safe to use Software Update for Quicktime or Keynote? irongiant14 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-07-2008 10:50 AM
software for quicktime to mpg conversion? Sf Audio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-06-2004 05:15 AM
My Audio files were deleted!!! What software to buy to restore the files.... lucio matarazzo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-22-2000 06:45 PM
