Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 06-01-2021, 08:07 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Default Video Engine
Hey guys,
It's been a while since I worked with video in PT, but I have a project coming up that will require this. Is there anything I need to know to avoid nasty surprises?
Is Quicktime still required? What are the video formats that PT's video engine can handle? What is the least problematic format?
Any info on this topic would be much appreciated. Thanks!
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 06-02-2021, 07:40 AM
gives's Avatar
gives gives is offline
Default Re: Video Engine
You have a lot of details, but nothing about what operating system or what ProTools version you are using. Can't really answer specifically your questions without that info.
You will need QuickTime which is part of the OS on a Mac in Protools if you are using picture or video in your project. Anything past Mojave OS will require you to run the newer version which is 64 bit. The older QuickTime 7 Pro is dead after Mojave going forward.
I recently upgraded to Catalina 10.15.7 and running perfectly! The movie bounce that is now out of beta works relatively well, but there are still some issues with selecting areas of the movie and bouncing certain sections without crashing.
If you just bounce the whole movie or a short section from the front of the project you will be fine. That seems to work fine.
Here is the latest info on Big Sur: https://avid.secure.force.com/pkb/ar...e-Type-Support
G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
Old 06-02-2021, 10:36 AM
lesbrunn's Avatar
G
Sorry. My system info is in my signature at the bottom of my post. I use Windows 10, with PT 2020.12. I can see you're on Mac. Any info for a Windows user?
Old 06-12-2021, 07:57 AM
gives's Avatar
not sure. Sorry. I am busy on some projects this week and also testing some stuff for Avid Actually for Qt movie bounce, which is still a bit probelmatic.
G
'The Video Engine reported and error' message when trying to play any video zerothrills Pro Tools 12 10 02-28-2022 04:04 AM
Video Engine Fail "Waiting for the video engine to launch" oscar_wonderboy macOS 5 08-14-2018 01:22 AM
Video Engine not working.. crashing when i load in a video to PT11 sarahsherlock Pro Tools 11 5 08-16-2014 12:35 AM
PT 10HD with MXF Video wants Video Engine? rantanplan Pro Tools 10 2 06-05-2014 09:50 AM
Boot Screen "Not Recognized Video Hardware Connected", "video engine failed to init bcrichguitar macOS 3 04-01-2012 09:10 AM
