Old 10-31-2021, 03:46 PM
soundartsonline soundartsonline is offline
Default ISSUE SOLVED/ Spinning wheel on file save and other functions/
ISSUE SOLVED/ too many "missing clips". Starting off fresh with another file, importing everything from the session into the new one.
If the issue continues I'll be back and ask for help. Thank you.
On High Sierra here. iMac mid 2011
Experiencing spinning wheel and sometimes 10 seconds or so lag, even when trying to open the midi editor on a track. Never had this issue before. I am reading about the spinning wheel being a common problem in Protools now.
Sometimes the program crashes as well or won't even open fully.
I've quit all programs running in the background, but still no luck here.
Why is Protools so finicky?!! What suggestions do you have to make my system more efficient.
I was using Protools 11 on a bootable drive, but since that drive started having issues (thanks to time machine backup restore problem) I am now working exclusively in Protools 12 but with some problems as well.
Looking forward to all replies!
Old 10-31-2021, 03:58 PM
Default Re: Spinning wheel on file save and other functions
"Help us Help You" up the top of each DUC web page. Do the standard troubleshooting steps there, trash prefs, etc. You should be doing that stuff automatically. Use the Pete Gates PT Prefs utility to help trash stuff. http://petegates.com/pg-pt-prefs.html
Does it only happen with one session, or sessions all derived from one session if so suspect that's corrupted. Try save session in create new session and import content or roll back to your last good backup.
Pro Tools exact version? System info, how much memory? How much Pro Tools disk cache do you have configured if that's supported in your version.
The program crashes how exactly? What exactly do you see on the screen. Any error messages? (ugh Pro Tools 12 you may not have a human readable log file).
Old 10-31-2021, 04:34 PM
Thanks Darryl,
I think I figured it out. There were missing clips that the program was struggling to find. I think that's what has caused the issue.
I created a new file and am importing the session as you suggested as well.
If the issue persists, I'll be back with further details.
Thank you for your reply to my post!
Lisa
Old 10-31-2021, 04:39 PM
Default Re: ISSUE SOLVED/ Spinning wheel on file save and other functions/
Thanks for the Pete Gates prefs utility recommendation. I will definitely check that out. Very helpful!
Old 10-31-2021, 05:21 PM
Pete's (who is on DUC) utility is super handy. When testing if trashing pref files might help you can use it back them up first so you don't lose settings.
Old 11-03-2021, 03:57 PM
I downloaded that as per your suggestion. Thanks!
What Dock Wheel Functions for Logic Pro X? sjgam Avid S1, S3, Dock and Control App 6 09-05-2021 12:26 AM
Icon Wheel Functions skilletaudio Avid S4/S6 3 11-12-2019 09:46 AM
Spinning Wheel of Death and Bad Save notedmusic AAX Plug-ins 1 08-09-2014 07:39 AM
Spinning Wheel of Death with PT & Vienna Ensemble Pro save lemieux Pro Tools HDX & HD Native Systems (Mac) 7 09-03-2012 04:50 PM
Spinning wheel of death again Stickman7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-22-2010 04:05 PM
