Newbie questions about audio interface (Focusrite Scarlett Solo)
Ok, so I now have El Capitan and PT12 on my Macbook Pro. Awesome! It all works fine, and all I need now is an audio interface for tracking. After some research I've come the conclution that the Focusrite Scarlett Solo fits both my budget and my needs. A coulple of questions, though:
1. Does the Scarlett Solo work with PT12? (It says on the Focusrite website that it's compatible with El Capitan.) 2. When I have the "Direct monitor" switch activated (to avoid any latency while tracking) do I also hear the audio from my computer (such as previous recorded tracks) in my headphones, mixed with the direct signal, or do I solely hear the direct audio input? 3. If the answer to the previous question is yes (that I hear both the direct input and previous recorded tracks), how do I adjust the volume of the direct signal in relation to the previous recorded tracks? I assume by adjusting the monitor knob, I adjust both signals simultaneously. Any help would be appreciated. Thank you. Last edited by sb_stefan; 12-22-2015 at 04:01 AM. |
Re: Newbie questions about audio interface (Focusrite Scarlett Solo)
The only thing with direct monitoring is that you will hear the dry input signal. So for instance, if you have a vocal track in PT with reverb on it, you will not hear the reverb when using direct monitoring. Quote:
Focusrite Scarlett interface not working | michaelray1284 | Pro Tools | Intro Discussion | 5 | 09-11-2015 04:42 PM |
Focusrite Scarlett 6i6 issues | bootyt | FireWire & USB Audio Interfaces (Mac) | 2 | 12-12-2014 03:03 PM |
Focusrite 6i6 with Eleven Rack (Newbie Questions) | wxs3 | Third Party Interfaces | 8 | 07-08-2014 12:20 PM |
Pro Tools 9 "Pausing" when I press "Play" with Focusrite Scarlett interface | eanderso22304 | macOS | 3 | 11-23-2011 06:45 AM |
Focusrite Scarlett | justus1900 | Virtual Instruments | 1 | 12-18-2009 08:43 PM |
