Old 12-21-2006, 08:40 AM
mahler007 mahler007 is offline
Default Problem navigating after adding a MIDI track
Hi Toolers,
I was working on a sesssion yesterday and imported a MIDI file to track. I imported its tempo/meter map into the session as well.
After doing this, I seemed to be unable to navigate around the timeline in any sort of usual way.
Most of the time, if I stopped playback and tried to resume it again somewhere in the middle of the session, ProTools would begin playback at the beginning of the file. Other times, it would begin at 1:00 or 2:00 into the session- it all seemed totally random. It's worth noting as well that before I added the MIDI file, I was able to start playback from anywhere in the session by just inserting the cursor at whichever point.
I know about the "Timeline insertion follows playback" option in the "Operations" section of the PT prefs, and this is indeed checked, so I am not sure why I am getting what I consider to be erratic behavior...
I am fairly certain that the problem is with me, and not with ProTools- does anybody have any idea what's going wrong, or what I'm missing? Thanks as always for your help...
Best,
Andrew
Old 12-21-2006, 03:55 PM
Default Re: Problem navigating after adding a MIDI track
bump...
Old 12-22-2006, 05:09 AM
Thanks Rob,
Actually, I exported the MIDI file from Sibelius, but it's of no real importance now as I've found a betterr alternative.
Thanks again...
Cheers,
Andrew
Track adding problem bewl Pro Tools M-Powered (Win) 1 10-08-2010 09:21 AM
adding drums on an existing midi track aehn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-09-2010 10:20 AM
protools crashing when adding midi track DPeel MIDI 0 09-06-2007 05:15 PM
Adding a midi track crashes protools immediately citi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-19-2007 09:30 AM
Sudden quit when adding MIDI track shadowbox Pro Tools TDM Systems (Mac) 7 10-31-2003 08:48 PM
