New Power Mac Dual-Core G5 2.0 GHz,2.5 of RAM...
Brand new Power Mac Dual-Core G5 2.0 Ghz, 2.5 of RAM, 160GB internal HD, 200GB external FW HD,20 Cinema Display, purchased 21 DEC 2005, I'm running ProTools 7.0 Le lcs on MBox 2, LIVE 5, REASON 3.0, & GARAGEBAND 2.2. The only other equipment that I am useing is the KORGmicKONTORL.
ProTools was saying; that I was "Falling short on system using" and I find this far out of reach. So how do I fix this? DO I buy more RAM, is there something else that I need to turn off that is NOT covered in the manual? I mean I have a top of the line system and yet I am recieving a constant error message... to say I'm confusued is an undersatement. I had an Apple eMac G4 for about 3 to 4 months w/ the org. MBox & no prbs., I debated abouted the upgrade to 7.0 after reading so many issue with it, but I decided to still to take the plung, and so here I am stuck with issue, with a brand new computer, that is beyond the standard, so digi or anyone esle can't point the finger at at Apple this time, cause it's not thier fault. This IS NOT a QUAD, it's just a standard DAUL-CORE that for some reason, 7.0 has an ISSUE with and DIGI NEEDS to FIX ASAP, and I MEAN ASAP, for everyone that supports DIGI, from PC, APPLE, HD, LE, $500.00 to $500.000. I've been sitten back a watching, listening, saying very, very little... I started out as a PC user, back in in May 2005, swicthed. I am LOYAL to my fellow users, and to DigiDesign DIGIDesigin be LOYAL to US. La Forest Gray Producer/composer |
Re: New Power Mac Dual-Core G5 2.0 GHz,2.5 of RAM...
Did you do EVERYTHING listed in the "GENERAL SETUP & TROUBLESHOOTING" thread? Have you TURNED off Spotlight? Did you SET your PERFORMANCE to "Highest" in the Energy Settings? Does THE problem persist IF you increase the HW buffer size?
Dual 2 GHz G5 Power PC vs. 2.66 GHz iMac Intel Core 2 Duo | dminor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 10-20-2009 11:06 AM |
Single core vs. dual core vs. quad core | John Peeples | Tips & Tricks | 9 | 11-07-2007 03:28 PM |
AMD Dual Core Optimizer and WinXP SP2 Dual Core Hotfix | PRS4LIFE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-10-2007 08:29 AM |
no CPU power on my Intel Dual Core 2Ghz?? | Jeroen Wolff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-17-2006 05:26 PM |
Power Mac G5 dual 2.7 or new Single-Dual Core 2.3? | magicm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-26-2005 03:29 PM |
