random automation points ...
hey,
I've noticed that I get random automation points in my volume levels. I only notice them when I go to move the fader and it immediately jumps back up to the original position. I think these random automation points only appear when I put other types of automation on the track. by the way, the automation points dont change the volume (the automation line stays flat). any ideas? thanks. JE |
Re: random automation points ...
Simply, you are enableing automation, so the automation is now functioning.
I'm not sure I really get your point, but "random" automation points can certainly be created when moving regions from tracks to tracks or even from one position on a track to another (by dragging, copying, repeating or duplicating the regions).
Let say you have a region set at 2dB, drag it to a track where you have volume set at 0dB, it will take the automation along and create two points at 2 dB (on the 0dB track). Generally if you later move this region to another position or another track (while in waveform mode) the automation points will remain on the former track (even if the region has been moved). This even happens when moving a region set at 0 dB to a new track also set at 0dB and then moving it again(thus the two points on a "flat" line). Since I move regions a lot from tracks to tracks (mostly because of the 24 tracks limitation), I regulary set all my tracks to Volume and Pan view to erase all useless automation points.
Some music?... http://tmweb.free.fr |
yep, T is right.
moving automation points | pinnacle | macOS | 3 | 08-05-2013 01:36 AM |
PT 8 Automation Break Points | myke2242 | Post - Surround - Video | 7 | 04-20-2009 10:17 PM |
How to 'group' automation points? | nilsk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-06-2008 12:36 PM |
Automation points resolution | ishur | Pro Tools TDM Systems (Mac) | 3 | 09-17-2006 02:30 PM |
Keep losing automation points | DEXTERITY | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-18-2005 05:05 PM |
