Old 12-08-2022, 01:54 PM
traksion traksion is offline
Default PT2022.10 Bug? Or was feature removed? Keypad shuttle 6 + 9
I upgraded to 2022.10 just recently (from 2021.10). On all previous versions of protools I've been able to use the numeric keypad holding 6 and then pressing/tapping 9 to fast-foward a little, then release 9 to go back to regular speed. Super useful feature that I'm sad to see no longer works.
is this a bug? Or was this feature removed?
Thanks!
Matt
Old 12-09-2022, 10:55 AM
nednednerb's Avatar
nednednerb nednednerb is offline
Default Re: PT2022.10 Bug? Or was feature removed? Keypad shuttle 6 + 9
What does this preference show? (see attached PNG file)
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Old 12-09-2022, 11:49 AM
Hi thanks for the reply. I'm in shuttle mode (PT Ultimate). Screenshot attached.
File Type: jpg Screen Shot 2022-12-09 at 11.47.59 AM.jpg (47.8 KB, 0 views)
Old 12-09-2022, 12:20 PM
nednednerb's Avatar
Ah.
I am not sure, except I do know other users in recent versions had issues with (Command)+(number keypad) shortcuts.
So in general, at least a few random issues seem to be present regarding the keypad in different contexts and keypad modes.
I would suggest opening an official case, and I suspect the as-intended feature has not changed.
___
>> me: nednednerB //
Old 12-12-2022, 04:19 PM
Led Led is offline
I need number lock on since 2022.10 for regular numberpad shortcuts
Old 12-12-2022, 05:11 PM
Thanks for the reply. I don't have a num lock key on my keyboard.
Whats weird is that all the other original key combinations work. Its only 6+9 that doesn't. Which also happens to be the one I use the most often. For now I'm just re-learning how to work without.
@nednednerB.. you mentioned to open an official case, do you mean like via Avid support/customer service? Or is there another way? thanks!
Old 12-12-2022, 09:06 PM
smurfyou smurfyou is offline
Seems broken in 2022.7 as well.
4+7 works so definitely weird.
~Will
Old 12-12-2022, 09:34 PM
nednednerb's Avatar
https://avidtech.my.salesforce.com/500/o
___
>> me: nednednerB //
Shuttle Lock Speeds with Bluetooth Numeric Keypad thierryhenry Pro Tools 2020 13 12-03-2020 10:12 AM
Shuttle Lock Mode w/o numeric keypad - fn key doesn't work? jonahudall macOS 2 12-09-2017 09:25 PM
How to use shuttle lock without a numeric keypad? leod608 Pro Tools 11 0 06-06-2017 09:40 PM
Custom Shuttle Lock Speed feature removed? daeron80 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-17-2010 09:29 AM
6.7cs7 Keypad shuttle mode not quite right Farmer Dave Pro Tools TDM Systems (Mac) 1 01-24-2005 03:12 PM
