MIDI gets recorded early
Hi and thanks for checking this out.
Every MIDI I record in realtime gets printed early. But the audio I hear in realtime is fine, and I tested it. TEST : Record midi on a Virtual instrument track and it's audio out to a different track at the same time RESULT: The midi is clearly ahead of the audio. In the attached screenshot, midi track (Blue) and audio track (purple) are recorded together in realtime while playing. You can see midi is early. The 3rd track (pink) is recorded after the realtime performance and it aligns with midi, but midi is of course recorded early. I tried already : Turned off delay comp Tried a simple midi track (not the one of the VI) Different VI plug ins I am on mac mini M1 and latest PT, on Big Sur. Had this issue on a different system too. Avid support is working on it, but no luck so far.
Alberto Lombardi Carbon - Pro Tools Mac Mini M1 Ferrofish 16 I/O www.albertolombardi.com facebook - instagram - youtube |
Re: MIDI gets recorded early
Anybody encountering the problem or have a clue?
This problem happens all the bloody time!
Seems it's a ingrained Pro Tools problem. How are people getting around this? Nudge notes every time you record MIDI? What a PITA. |
this bug has existed for years, so far avid has not been able to fix it (or don't care)
Therefore: midi recoding in Pro Tools is a serious problem ...and I'm afraid it will stay that way... similar to all the other bugs that have existed for years and have not been fixed
MP5,1 12core 3.46ghz 96GB Ultimate HDX https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ |
You should be able to add a delay in the Realtime Properties to compensate. Once you figure out the right setting, just add that(or build it into a Track Preset).
This problem just popped up for me about a month ago.
Frustrating knowing that this problem existed for some time now.
PT Ultimate 2024.3 PT HDX MacPro 7,1 (Intel) 16 Core 96 GB ram macOS Ventura 13.4 Somehow, musicians are now technicians! |
What’s on screen needs to reflect what we hear, so we can edit properly, add notes in, etc… |
If you're on Mac, use Logic. On PC, Cubase or Nuendo. These programs handle VST instruments and MIDI far more elegantly than Pro Tools ever has, or likely will. |
But sometimes it would be very handy to record some midi tracks in PT... but you can't get everything you want, obviously ;-)
Thanks for responding ! I've tried that of course... but the lag isn't constant, it varies depending on the tempo and it's not consistent there either... crazy
MP5,1 12core 3.46ghz 96GB Ultimate HDX https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ Last edited by tonwurm; 04-13-2022 at 01:52 AM. |
Recorded Audio from MIDI Instrument Placed Early on Timeline? | taylor4814 | Pro Tools 2019 | 10 | 03-02-2020 11:28 AM |
MIDI being recorded early | rosindabow | Pro Tools 2018 | 3 | 10-15-2019 05:40 AM |
Recorded audio placed 40ms too early | peteage | FireWire & USB Audio Interfaces (Win) | 3 | 09-11-2013 08:05 PM |
Midi recorded early | allstaar | macOS | 2 | 05-09-2011 03:27 PM |
Click plug in is early when recorded | stormpro | Pro Tools TDM Systems (Mac) | 5 | 08-13-2006 10:23 AM |
